Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-27-2019, 02:27 PM | #1 |
Drives: 2017 Subaru BRZ
Exhaust rubbing on diffuser
I just bought a used exhaust and one of the tips is rubbing against the diffuser. The other side is perfectly aligned. Is there any thing I can do besides going to a shop to get it fixed? I was looking into the kartboy extended hangers, but not too sure about them.
05-27-2019, 03:06 PM | #2 |
Drives: 17 Asphalt 86
The extended rubber hangers should solve it.
If it is barely rubbing it should give you the clearance you need. It's odd that only one side is rubbing though. |
05-27-2019, 03:21 PM | #3 |
What exhaust is it? If one side is good and the other is not then something is wonky.
05-27-2019, 03:23 PM | #4 |
Its the GReddy CS-GTS Ver. 2 , it retails for 1500 so this shouldn’t happen.
05-27-2019, 05:35 PM | #5 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
I would try loosening up every bolt up to the cat, let it rest, and then tighten up again. With it being a Greddy exhaust in that price range, it should fit perfectly.
Similar Threads | ||||
Exhaust rubbing. | phantasticity | Engine, Exhaust, Transmission | 1 | 08-30-2016 11:38 PM |
Just got my Borla Exhaust + Diffuser | ggpaul | Engine, Exhaust, Transmission | 21 | 05-15-2015 04:53 PM |
That diffuser with the center exhaust | Yamajee | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 05-26-2014 03:39 PM |
FRS/BRZ/86 OEM Diffuser & TRD Exhaust? | Re~Mix | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 02-19-2014 09:55 PM |
single exhaust diffuser | VENOM~ | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 11-06-2012 10:07 PM |
