Another “will not go into gear” post
I purchased my BRZ 3 yrs ago with 44k on the clock. I now have 123k miles on it and replaced the clutch once to the ACT lightweight flywheel package. Did not like this at all so I went back to the stock flywheel and stock EXedy clutch. I was having trouble with it going into gear before replacement and just assumed it was a burned up clutch disk. Since replacement it will not go into any gear but 3rd with the motor running. Yes the clutch is installed correctly, no visible leak from the slave or master cylinder, the fluid has been regularly changed with GL-5 fluid. I’ve read though all the posts about this and never read a final reason for this. I’d upload a video but photobucket refuses to load it. Just looking for a solution, cars been down for two weeks now.
Check your shifter plate. These have been know to get misaligned during tranny work and cause all sorts of issues.
https://demos.starbase7.net/t3Portal...64040893092195
| The Following User Says Thank You to Tcoat For This Useful Post: | jcw99 (05-25-2019) |
http://www.ecmtuning.com/cdelp/brz/c...b-movement.mp4
Here is a link to a bore scope video of the clutch movement. I still can not get it to go into gear with the motor on. I adjusted the shifter as the link above suggested also and still no luck. Sent from my iPhone using Tapatalk |
https://drive.google.com/file/d/1FYn...v4zssvG8q/view
Better link Sent from my iPhone using Tapatalk |
I fixed it! The clutch disk was binding on the input shaft. After removing and inspecting the clutch small burs were found on the clutch disk. I used a small file and removed the burs. Cleaned the shaft, applied the HT grease and tested the disk and throw out bearing movement. Reinstalled everything and it worked perfectly.
| Not your typical 1st and 2nd gear issue post | jesslax32 | Issues | Warranty | Recalls / TSB | 12 | 05-19-2018 07:38 PM |
| Gear indicator (G-on) shows 2 when in 3rd gear | c8Face | BRZ First-Gen (2012+) — General Topics | 31 | 07-07-2017 08:23 PM |
| Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl | jakebrz | Issues | Warranty | Recalls / TSB | 14 | 06-06-2016 07:28 PM |
| alright my tenth post so i can officaly post in the marketplace | destiny86 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 02-04-2016 01:49 PM |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 09:39 PM |
