Old 05-20-2019, 08:25 PM   #1
thE_iyE
Drives: 13' FR-S
Random P0352
I get a random P0352 code once every 3 or so drives. Sometimes just the light will come on, no misfire associated, other times it will misfire so bad I can feel the engine shake and the traction control light comes on. It can also last for a few seconds or more.
I've flipped coils between cylinder 1 and 2, and even replaced the coil, code remains p0352 (cylinder 2). I cant troubleshoot this as its random and momentary. I've been told to check the harness, and I've checked continuity while filding/bending the pigtail/connector for cylinder 2 with no change in any 3 of the wires.
Anyone else experienced a problem like this?
Also, where can I buy a new harness with the updated coil plugs? Where can I get just a pigtail to try and replace the connector on plug 2?
Sent from my SM-G960U using Tapatalk
thE_iyE is offline   Reply With Quote
P0302, p219a, p0352, p119f, used car woes. Dara321aaa Issues | Warranty | Recalls / TSB 8 04-29-2019 09:44 PM
P0352 - Coil Pack or Actual Curse? thE_iyE Issues | Warranty | Recalls / TSB 11 04-20-2019 07:33 AM
Recurring P0354 P0352 Mr.Scion Issues | Warranty | Recalls / TSB 8 02-12-2019 12:56 PM
P0352 and TCS issue RavioliG Issues | Warranty | Recalls / TSB 3 08-18-2016 07:57 PM
P0352 Felix7007 Issues | Warranty | Recalls / TSB 4 08-03-2016 07:25 PM
