05-15-2019, 07:34 PM | #1 |
Drives: 2017 86
Konig Hypergram $500
4 Konig Hypergram Konig hypergram in matte grey . 17x9 +40 offset 5x100 bolt pattern . Light weight flow formed wheels 17 lbs each. Clears 4 piston bbk. No rash dents or cracks. Note: one of the wheels is difficult to balance.
$500 plus ship. Last edited by invaliduser; 05-16-2019 at 09:12 PM. |
05-16-2019, 12:14 PM | #2 | |
Site Moderator
Drives: ichi 86 Project
Please follow the Member Classified Rules (#2) or I'll delete the thread.
ichi |
05-16-2019, 12:18 PM | #3 |
Drives: 2017 86
My bad, I forgot on this one. Will update tonight
Sent from my SM-G973U1 using Tapatalk |
05-16-2019, 12:41 PM | #5 |
Drives: 2017 86
Never tried with stock struts. They cleared Feal 441s just fine.
05-16-2019, 04:28 PM | #6 |
Drives: Subaru BRZ Limited
05-16-2019, 04:33 PM | #7 |
Drives: 2017 86
Anyone that has mounted and balanced knows what it means. If it takes alot of weights to balance out the wheel then the tire isn't seated properly or the wheel could be bent.
05-16-2019, 04:45 PM | #8 |
Drives: 2017 86
For reference I had Rival 1.5s on these (245-40-17) and it took 4 oz of weights to balance out.
05-16-2019, 09:15 PM | #9 | |
So, assuming the tire was seated properly are you saying one of the wheels is bent? |
05-16-2019, 09:37 PM | #10 |
Drives: 2017 86
So here's the the thing...
I could have posted these for sale and not mentioned anything about a wheel being tough to balance. Because most people don't have the equipment or knowledge on mounting and balancing a set of wheels and tires. And would not have known that there was an anomaly to begin with unless the shop that did the work we're nice enough to let then know. My guess is most would not. But I do have the access to the above mentioned equipment and the knowledge on how this process works.... and I know that it's not a normal situation to put 4oz of weights on a wheel to balance out. So I noted that in my original post. I don't have equipment to detect if a wheel is bent. But I have mounted and balanced this wheel twice and I can tell you it took 4oz of weights to balance the second time I put a tire on this wheel. I do not recall how it balanced out the first time. If this bothers you, I would suggest you not purchase these wheels or any wheel that is in this price range. Me personally, as an autocrosser with this setup, it's light'ish' and it's a pretty good looking wheel with a nice finish. I would buy it if looking for a really good STX bang for the buck. Sent from my SM-G973U1 using Tapatalk |
The Following 3 Users Say Thank You to invaliduser For This Useful Post: |
05-16-2019, 10:47 PM | #11 |
yeah, I think you're right and I think anyone would appreciate your honesty. as someone who just pays the tire shop to mount and balance wheels, I would have no idea either way as long as they held air and didn't vibrate I would say they're totally fine. I think they're good looking wheels and seem like a good deal for a nice light weight wheel. good luck with the sale!
The Following 2 Users Say Thank You to JoeC For This Useful Post: | invaliduser (05-16-2019), Pat (06-03-2019) |
05-23-2019, 01:10 PM | #12 |
Purist
Drives: 2013 FRS - Hot Lava
17X9 +40 will clear stock front struts. 9" +45 will not unless youre stretching a tire.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
The Following User Says Thank You to Westen86 For This Useful Post: | Face_Plant (05-23-2019) |
06-03-2019, 04:56 PM | #13 |
Drives: 2017 86
bump
06-07-2019, 01:37 PM | #14 |
Drives: M4
what would it cost to ship to 22182?
Similar Threads | ||||
Konig Hypergram? | carczar_84 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 96 | 12-15-2023 07:40 PM |
Bronze konig Hypergram 18x8.5 +38 | 86socal | Wheels and Tires | 0 | 08-11-2017 11:08 PM |
Konig Hypergram 17x8 +40 | TheMOPs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-18-2017 11:03 AM |
Konig Hypergram 17x8 +40 16.8lbs, Hankook Evo2 215/45/17 19.3lbs | SuperTom | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 06-09-2017 06:12 PM |
