Drives: i walk the streets.
Back to Stock Sale: SBD300 Turbo Kit, Full Q300 Exhaust, Crawford AOS, AEM Wideband
Car went back to stock as the new owner has plans that don't involve the FA20. Pile of stuff in my shop needs to go. I'm in Southwest Louisiana (Lafayette/Lake Charles area) and can meet in Beaumont/Houston area for the larger ticket items if someone is interested. I accept PayPal, asking prices do not include shipping.
I'm open to reasonable offers, feel free to ask, worst I can do is say no. ----- TURBO KIT SOLD SBD300 v1 Turbo Kit This is the original v1 SBD300 turbo kit. Comes with all pictured, nothing more. Kit has less than 5k miles on it. This was a weekend car for me and didn't see much use. While this isn't as refined or as powerful as the current SBD offering, it was a great kit and the car felt really sorted on it. The Good: * No play in shaft, no schmoo/leaking oil in turbo, spins freely * 7psi Wastegate * Manifold, intercooler, charge piping, and all brackets included. * Intercooelr outlet pipe has been replaced with the larger "SBD350" pipe. * AEM Dry Flow filter in place instead of original included one. * Turbosmart BOV replaced the original SBD one. * All charge pipe hose clamps replaced with stainless aircraft style t-bolt clamps * SBD Pre-welded OE oil pan for turbo oil drain included * Fumoto Oil Valve installed on oil pan for easy oil changes * Metal Subaru WRX OE PCV valve included * Vibrant Performance vacuum manifold included (makes it easier for tapping BOV, boost gauge, etc...) * Delicious Tuning (MAC 3-port Valve) EBCS included... requires tuner to enable * Downpipe wrapped in DEI Titanium. The Bad: * The 3bar MAP broke upon removing from the intake manifold. You'll need a new one. They're about $65 from Delicious Tuning. (Maybe cheaper elsewhere?) I'll throw the broken one in the box, but it's not useable. * Heat wrap on oil return line is coming off. It works, but it's not pretty, if you're in to aesthetics you'll want to replace it. * There may be missing a few random mounting bolts, they are all readily available from hardware stores. One missing bolt for sure is for the upper intercooler bracket. * I'm including the turbo manifold and exhaust gaskets, but you may want to replace. Manifold gaskets not included. You want OE or GrimmSpeed ones. * Not bad per se, but you'll need to acquire some vacuum line and what not. This is readily available at any auto parts store. Same goes for items like hose clamps and zip ties. You'll need to provide your own. Asking $1700. This would likely ship out in two boxes. I'll cap off things like the intercooler and turbo inlets along with using copious amounts of bubble wrap and packing material to protect it. I accept PayPal and will ship insured to confirmed addresses only. ----- EXHAUST SOLD Invidia Q300 SS Tip Catback w/catless front and overpipe Second item is a full Invidia Q300 cat-back exhaust including the catless front pipe and over pipe. I'd like all of this to go to one place. Shipping might be a beast, but I'm willing to ship if we can agree on price. Looking to get $650 for the whole exhaust. ----- Crawford Air Oil Separator Not much to say here. It's Crawford's AOS, as pictured, $300ish new, asking $200. This'll easily go USPS Priority Mail. This is their original one. ----- AEM Wideband Failsafe 30-4900 As pictured. Self-explanatory. Some scratches and sticky on bottom left over from pod mounting and extraction from pod, doesn't affect face of gauge or operation. Sensor not pictured, but it IS included. $325 new? Asking $225. ----- 52mm / 2 1/16" Autometer ES Boost Gauge (Model 5907) It's a mechanical boost gauge that displays boost. $50. ----- Block8Head Custom Vent Pod, Dual Gauge Custom made pod that holds 2 52mm gauges. You can search the Internet for Block8Head if you want to see more of his work. This ran $120, but I did scratch it up a bit getting the gauges out of it, let's call it $50. Should be able to hide the scratches with some matte black paint. If you want both gauges and the pod, we can work out a deal. -----
--- Deebeaux
--- Former '13 FR-S Turbo Owner Last edited by Deebeaux; 06-11-2019 at 10:28 PM. Reason: Updated sold items. |
Bumpity bump.
I found the box for the AEM wideband, that's included now. I should also note that very little if any wires were cut, so it's good to mount anywhere without a lot of splicing and hackery to the gauge hareness. Also, I found the original SBD300 throttle body inlet pipe, I'll toss that in the box with the turbo. There's no reason you'd use it since the SBD350 one is bigger, but it's spare in case something weird happens. All prices are "or near/best offer." Worst I can do is say no, but if it's a reasonable offer, I won't.
--- Deebeaux
--- Former '13 FR-S Turbo Owner |
Turbo kit sold, everything else still available.
--- Deebeaux
Drives: 13 BRZ
Sent pm
Turbo kit and exhaust sold.
AOS, gauges, pod still available.
--- Deebeaux
JDM Vaping Stance Nation
Drives: 2013 White
Pod still available?
Clueless
Drives: Blue BRZ Limited
Hi, I'm interested in the AEM wideband gauge if it is still available!
| For Sale full built crawford | Greg5280 | Transmission and Driveline | 1 | 02-24-2017 11:16 AM |
| Stock cat-Back Exhaust on sale Ottawa | vignesh | Canada Classifieds | 1 | 06-30-2015 08:48 PM |
| Full stock exhaust for sale | Anthony7515 | Engine, Exhaust, Bolt-Ons | 0 | 06-16-2014 11:29 AM |
| Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? | fooddude | Engine, Exhaust, Transmission | 39 | 12-15-2013 02:05 PM |
| INJEN Dual Tip Cat-Back Exhaust now for sale // in stock! | GuerillaRacing | Engine, Exhaust, Bolt-Ons | 13 | 03-01-2013 04:34 PM |
