Old 05-08-2019, 08:29 PM   #1
Bryan86
Drives: '16 CWP BRZ
Car acts weird after not driving it for a couple of days
So i noticed that if i don't drive the car for at least 3 days it starts to act weird. One, my e brake handle becomes very loose and then feels normal after driving for like 30 minutes. Two, on my first drive out while the car is still somewhat cold, the car likes to vibrate violently going over 50 mph but goes away a minute later. Three, again on my first drive out, when i put the car in 1st gear it doesn't start rolling. I would have to give it some gas for it to start going, but i just think it's really weird that the car wouldn't move when i bring out to the bite point but this eventually goes away when the engine or transmission is warmed up. I checked my tires and see if my lug nuts were on tight and everything seems fine, so i have no idea what the problem is. If anyone can please help thank you!!!
Mods:
Invidia N1
Invidia catless front pipe
Tomei overpipe
Tein coilovers
Edit:Car will act normal after driving it for a while but problems will come back when i don't drive it for a couple of days
Last edited by Bryan86; 05-08-2019 at 08:36 PM. Reason: Car will act normal after driving it for a while but will come back when i don't drive it for a couple of days
Bryan86 is offline   Reply With Quote
Old 05-08-2019, 08:51 PM   #2
Grady
Grady's Avatar
Drive it every day, problem solved.
Old 05-08-2019, 09:58 PM   #3
jflogerzi
jflogerzi's Avatar
Used or new? Do you have a tune or stock? Your still on OEM headers? What your describing are mechanical issues... Describe cold as in what temperature?
2013 Series 10 FRS #553
Old 05-08-2019, 10:12 PM   #4
Bryan86
Drives: '16 CWP BRZ
Bought it new. Stock tune. Oem headers. Cold as in 70-85 degrees.
Old 05-08-2019, 10:15 PM   #5
jflogerzi
jflogerzi's Avatar
Only thing I would say is check your modified exhaust parts for loose bolts, leaks, or clearance issues. When did this start happening? any CELs or codes?
Old 05-08-2019, 10:35 PM   #6
Bryan86
Drives: '16 CWP BRZ
No CEL or any codes. It randomly just started happening like a week or two ago but i’ll def check for all this during the weekend.
Old 05-09-2019, 12:03 AM   #7
humfrz
Mods:
Invidia N1
Tomei overpipe
Tein coilovers
e-brake handle - do you set the e-brake when it is parked for that period of time? If so, maybe the cable is just temporarily stretched. Nothing to worry about.
Car vibrating over 50 mph - maybe the tire(s) just had a temp flat spot which goes away when they get warm. Maybe check the tire pressure.
Car not moving in first. You might check the clutch adjustment and the clutch system fluid level.
humfrz
Bryan86 (05-09-2019)
Old 05-09-2019, 07:24 PM   #8
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Sounds like your parking brake is sticking.
Your handle is loose because the brake shoes aren't retracted.
The car shudders because the brake is getting very hot and grabbing.
The car doesn't start rolling because the parking brake is stuck.
Vibration/heat eventually nudges the brake shoes to free the rotor completely.
The Following User Says Thank You to RZNT4R For This Useful Post:
Driving cross country in the next couple months rainmonkey BRZ First-Gen (2012+) — General Topics 24 02-17-2016 07:58 AM
Winter driving: dry days only? 1Cor10:23 CANADA 38 01-23-2015 07:23 PM
How many days the battery last without driving the car? djmm Scion FR-S / Toyota 86 GT86 General Forum 35 04-02-2014 06:13 PM
Couple of days to kill in Ft Lauderdale/Hollywood area, cool things to do/see? Bad Habits Southeast 3 01-14-2014 06:02 PM
