Old 05-08-2019, 07:31 PM   #1
eric555
Drives: gt86 aero kit
Question Brz edit removal help please
So my car been tuned with brz edit and i want to retune the car with ecutek
My question is how do i remove the brz edit rom from the ecu
And is there any chance ecutek can re-write brz edit
The previous tuners that did brz edit is on leave and will only be back in 3 weeks
So just hoping if i can skip the wait and get the car retuned
eric555 is offline   Reply With Quote
Old 05-08-2019, 10:03 PM   #2
jflogerzi
jflogerzi's Avatar
If you have your original ROM, that is all you need.
2013 Series 10 FRS #553
Old 05-09-2019, 06:05 AM   #3
steve99
Wont work .
If you try writing over brzedit locked ecu with ecutek it will fail and you will loose the ecutek licience.
Brzedidt locks ecu with different seed key change than ecutek.
Old 05-09-2019, 06:11 AM   #4
steve99
To unlock brzedit locked ecu yourself you would need the brzedit tune system and then write a stock rom with brzedit system to unlock ecu.
Im assuming you dont own brzedit system or know someone with brzedit system.
Good news is you can get ecutek in england to unlock the brzedit locked ecu for you if you own ecutek and have an ecutek licience.
You will need to contact ecutek in england and set up a time whwn they can remote access your computer connected to your car with ecutek cavle and licience ready.
The guys at ecutek will clean off the brzedit remotly for you.
Warning do not try to directly flash your brzedit locked ecu with ecutwk yourself. If will try to flash thn fail and loose you ecutek licience.
Contact ecutek support in england aengland and tell them you ecu is brzedit locked. I believe the unlock servoce is free if your ecutek customer ie you own cavle and licience
brzedit, ecutek brz frs, removal
New video edit Stealth Gt86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 01-09-2019 12:45 PM
Brz Edit automotivated Software Tuning 1 02-20-2016 01:56 AM
EcuTek vs BRZ-Edit regal Software Tuning 205 03-14-2014 09:59 AM
BRZ Edit on FI application crook Forced Induction 7 06-15-2013 02:59 AM
Edit Thread Title. Msnicoleeeee Site Announcements / Questions / Issues 2 05-02-2013 04:49 AM
