Old 04-29-2019, 01:24 PM   #1
caddyshackin
Drives: 2016 FR-S RS 2.0
Question OFT to Ecutek
Hi all,
I feel like I've exhausted myself searching the internet for hours on this subject, guess it's time to stop being a lurker and ask for some help!
I've seen in the past on other posts that apparently people can open and edit non OFT roms in RomRaider. I'm familiar with RomRaider and how it works (I think so anyways ) and I can open/edit all my old tune files just fine in it! However, as soon as I open anything with Ecutek, its uneditable with romraider. And since OFT has the 'racerom features' I can not just flash the OFT tune using Ecutek. I can't seem to be able to compare roms/images in Ecutek either! (probably just lack of how to)
My latest thought was to open my .ori file from the OFT and do a compare file in rr, but since it seems I opened it in Ecutek (didn't save it or anything, just a quick peek), the file throws corrupted errors if I try to open it in RR.
Any help or guidance from anyone who likes a good challenge would be greatly appreciated.
caddyshackin is offline   Reply With Quote
Old 04-29-2019, 02:19 PM   #2
tomm.brz
Drives: brz 2017 hksv2
You won't ever open a ecutek saved file with romraider, ecutek adds patches to it as soon as you save it
Also, compare feature is available only to accredited Master Tuner
So you can't compare them, you only can compare tunes by opening EACH table and see the differences
If you tune your car with ecutek, you must start from a stock rom provided by ProEcu (help -- ecutek update -- Update rom files... and find your Cal ID)
and you have to forget about romraider
The Following User Says Thank You to tomm.brz For This Useful Post:
randomthoughts (04-29-2019)
Old 04-29-2019, 05:00 PM   #3
caddyshackin
Thanks, I appreciate the information. Off the top of your head, do you happen to know what maps are modified?
Just comparing stage 1 to stage 2, I see a total of 11 tables are changed. If its unknown, I'm going to go through all maps one by one tonight, just curious!
Old 04-29-2019, 06:50 PM   #4
tomm.brz
If you are using OTS maps th3n just open them with romraider to see the differences with a stock map opened too, and the apply the changes to ecutek tune
Old 04-29-2019, 07:27 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Or any ROM that doesn't have LC/FFS from OFT (many can be found on here). I have used a stock ROM in Romraider to edit some tables before opening in EcuTek.
Having the EcuTek compare function has it's benefits but only for Tuner dongles
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-29-2019, 10:30 PM   #6
Tor
Tor's Avatar
Drives: Toyota GT86
Find a stock unmodified tune (i.e. not an OFT tune). Get the latest tune that is compatible with your calid.
Open it in Romraider and compare to your current RomRaider/OFT tune. Copy all changes over to the stock unmodified tune - save it.
Open this new tune with ProECU and you have an Ecutek tune to work from there.
As Kodename47 said, there is no issues opening a stock tune (with or without modified tables) in ProECU. Only problem is opening tunes that have hacks applied - like calid hacks/LC/FFS etc.
Tor is offline   Reply With Quote
Old 04-30-2019, 01:22 PM   #7
caddyshackin
From what I can tell, this may be impossible. My definitions aren't compatible in RR. The OFT definition throws my .ori file into a tailspin (to be expected). Can't seem to find any stock defs/roms for a ZA1JF40C. (damn you rs 2.0!!)
I'm 100% sure I'm somehow making this harder for myself. BUT IT FEELS SO CLOSE!
Old 04-30-2019, 02:26 PM   #8
tomm.brz
mostly, f40c oft tune is a hacked b01c or something similar
you could then treat your car like it has a b01c, modify that tune (you will find a vanilla b01c here on the forum) and then force ecutek to flash it
OFT with ECUTEK?? chazmuska Software Tuning 1 01-16-2018 04:52 PM
used FR-S with Ecutek slowautoxr Software Tuning 13 09-17-2017 06:34 AM
WTB ECUTek used xoBethxo Want-To-Buy Requests 0 04-22-2016 02:05 PM
FS Ecutek SubaSteve Engine, Exhaust, Bolt-Ons 7 03-25-2016 09:22 AM
ecutek ? mrnibbs Software Tuning 39 01-26-2014 11:40 PM
