Old 04-28-2019, 01:22 PM   #1
Zer0
Drives: 2015 frs
Firewall clearance and engine height?
I'm in the middle of an engine swap, and was interested in finding out what others who are doing engine swaps are getting for engine placement.
The measurements I'm interested in most are
1)firewall to nearest head clearance?
2)center of crank bolt height over the lower radiator support? Not on the on the rib but the area below it with the holes.
3)Engine type, and mount brand?
This may help others deciding on an engine and mount kit if they are looking for a certain motor placement.
So far I'm 5/16" from the firewall on my passenger head, and 3 1/8" above lower radiator support at the center of my crank bolt. LT4 custom swap Vorshlag transmission mount with engine mounts being made by me. Measurements may change slightly until motor mounts are completed. Head to firewall clearance won't change.
Zer0 is offline   Reply With Quote
Old 04-29-2019, 08:53 AM   #2
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I can get those measurements when I get home. You pushed the engine way back.
DustinS is offline   Reply With Quote
Old 04-29-2019, 09:10 AM   #3
Zer0
Drives: 2015 frs
I tried thanks for the response. I was thinking no one was as interested in finding out where other people have their engines sitting in a swapped FR-S or BRZ.
Old 05-02-2019, 03:52 AM   #4
Zer0
Drives: 2015 frs
@DustinS did you get a chance to get any measurements?
Old 05-02-2019, 08:47 AM   #5
DustinS
DustinS's Avatar
~5 1/2" up from radiator support. 2 3/4" from back of passenger side head to firewall. There was a rubber plug on the firewall though. So maybe 1/8" more than that.
Old 05-02-2019, 09:30 AM   #6
Zer0
Drives: 2015 frs
Thanks I appreciate the information.
Old 05-02-2019, 04:22 PM   #7
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
My heads are 80mm from head to firewall.
Using the second bolt hole location on CX mounts.
spitsnaugle is offline   Reply With Quote
Old 05-02-2019, 04:35 PM   #8
Zer0
Drives: 2015 frs
Thanks for sharing the info. If you ever get a chance to measure the engine crank height above the front crossmember let us know. Maybe later we can get these measurements plus corner weights.
Cable through engine Firewall Plug help Autocon Cosmetic Modification (Interior/Exterior/Lighting) 5 08-04-2016 07:07 PM
rattling inside engine bay near firewall driver side Tvars Issues | Warranty | Recalls / TSB 2 11-20-2015 04:19 PM
