Old 04-17-2019, 01:24 PM   #1
kensta
kensta's Avatar
2018 clutch master cylinder vs 2014 clutch master cylinder same?
Can anyone confirm if a 2018 BRZ/FRS clutch master cylinder will work on a 2014 Subaru BRZ? The only obvious difference is that the 2018 has a black reservoir cap vs the 2014 being a yellow cap on the reservoir. They have different part numbers.
2018 - 37230CA030
2014 - 37230CA010
Thanks.
kensta is offline   Reply With Quote
Old 04-19-2019, 01:04 AM   #2
kensta
kensta's Avatar
I have confirmed the 2018 clutch master cylinder works for 2014 models and below. I installed it on my car with no issues.
Clutch Master cylinder - bleeder screw size? Joesurf79 Engine, Exhaust, Transmission 3 12-28-2019 08:16 AM
Any clutch master cylinder options that are more compact? Clash0901 Engine, Exhaust, Transmission 3 07-22-2018 06:32 PM
Broken Clutch Master Cylinder eddyy Issues | Warranty | Recalls / TSB 6 05-15-2018 06:15 AM
Clutch Master Cylinder hard line Fiting size? celek Engine, Exhaust, Transmission 7 03-12-2018 08:30 AM
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 04:48 PM
