Old 04-17-2019, 11:27 AM   #1
AK the Great
Drives: 2015 FR-S A/T
Front right strut keeps blowing out after curb impact
I kissed a curb pretty hard on the front right back in October 2018, and had a load of work done at a local collision specialist.
Completely bent the control arm in half, and had brake fluid leaking.
I thought it was going to be a total loss with a bent frame, but insurance ponied up and shelled out over $5000 in repairs.
Repairs were finished on October 17th, and she felt like new again.
Fast forward two months into late January, and I'm seeing an oil spot being dropped by the front right area, shortly followed by a thumping noise.
Took it back to the collision shop and they diagnosed it with a leaky strut, and replaced it under warranty with an OEM strut
About a month later in mid-March..... same exact issue.
Another OEM strut replaced under warranty.
One full week later..... same exact issue.
I took it to a local Toyota dealer and they looked at it and diagnosed the same problem, blown strut, no other problems.
Collision shop is now going to order an aftermarket strut (not sure which brand) and going to be replacing it free of charge next Thursday.
After three blown struts I hope this will be the fix.
Has anyone ever experience anything like this before?
What else could be causing the problem that neither the collision shop or the dealer has noticed?
I do live in western Massachusetts where potholes have been bad this year, and the shops suggest I stop "slamming" the potholes....But I've been diligent in dodging anything major. This can't be the problem...
I'll try to decipher the parts list from the estimate;
Front Suspension:
Repl - RT Lower cntrl arm
R&I - ENGINE HARNESS AUTO TRANS
Repl - RT Lower cntrl arm bolt
Rpr - Susp Crossmember
Repl - RT Knuckle
Repl - Stabilizer bar
Repl - RT Stabilizer link
Repl - RT Strut
Repl - RT Stabilizer link nut
Repl - RT Spring seat
Repl - RT Seal
Repl - RT Strut mount
Repl - RT Hub assy
Steering Gear & Linkage:
Repl - RT Outer tie rod
AK the Great is offline   Reply With Quote
The Following User Says Thank You to AK the Great For This Useful Post:
Strife26 (04-17-2019)
Old 04-17-2019, 11:57 AM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
Something has to be tweaked, it's not bad luck 4 parts in. MacPherson struts are simple, that's why they're so prevalent. The strut is the upper control arm. The LCA locates the lower ball joint, the strut and spindle hold everything up and down. Not a whole lot going on.
Or the same guy is doing the job every time and butchering it?
If the spindle/upright/whatever Toyota calls it were to be bent it could side load the strut and cause a leak?
maslin is offline   Reply With Quote
Old 04-17-2019, 12:50 PM   #3
If the spindle/upright/whatever Toyota calls is were to be bent it could side load the strut and cause a leak?
Yep. Something is side loading it somehow. There is no way that it just coincidently blew 4 like that even if the worst installer in the world worked on it.
maslin (04-17-2019)
Old 04-17-2019, 01:07 PM   #4
maslin
Benz Tech
Something in this area, it wouldn't have to be a lot.
The Following User Says Thank You to maslin For This Useful Post:
Tcoat (04-17-2019)
Old 04-17-2019, 02:41 PM   #5
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
isn't that the wheel bearing assembly?
Couldn't it also be the control arm thats bent?
RickyRacer is offline   Reply With Quote
Old 04-17-2019, 03:34 PM   #6
maslin
Benz Tech
That contains the wheel bearing, yes.
Bent lower control arm wouldn't really load the strut in that way. It would move the wheel in or out at the bottom, or forward/back. The ball joint would isolate any force from the strut.
Bent lower control arm was replaced per the OP.
The Following 2 Users Say Thank You to maslin For This Useful Post:
RickyRacer (04-17-2019), strat61caster (05-21-2019)
Old 04-17-2019, 07:56 PM   #7
norcalpb
norcalpb's Avatar
You should post exactly what parts were replaced from your receipt.
Old 04-18-2019, 10:37 AM   #8
AK the Great
Thank you for all the responses.
Front Suspension:
Repl - RT Knuckle
Repl - RT Strut
Repl - RT Seal
Repl - RT Hub assy
Once I get home from work I might be able to snip out any personal information and post the full estimate.
norcalpb (04-18-2019)
Old 04-18-2019, 10:56 AM   #9
maslin
Benz Tech
Front Suspension:
Repl - RT Knuckle
Repl - RT Strut
Repl - RT Seal
Repl - RT Hub assy
You have a new spindle (knuckle). Looks like basically everything on the corner was replaced.
I'm out of ideas. Maybe back to the same Bubba replacing the struts and never getting the spring on the hat/strut correctly?
Old 04-18-2019, 11:34 AM   #10
AK the Great
Does replacing a strut involve tearing down that whole right front area?
If not, maybe I should have them break down that whole front right and reassemble it?
Old 04-18-2019, 11:35 AM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Did they check the frame to see is anything is tweaked in that regard?
What did the alignment look like after?
Old 04-18-2019, 11:43 AM   #12
maslin
Benz Tech
The complete strut comes out in 5 minutes. Wheel off, 2 big bolts to the knuckle, brake line bolt out, hood open, top nuts off, strut on the bench.
I did both front lowering springs in maybe 20 minutes max, the rears take a good bit longer with the trunk liner and LCA in the way.
MacPherson front suspensions are silly simple, that's the point. There has to be something else going on. I can't imagine you can bend a spring, but maybe?
Old 04-18-2019, 11:46 AM   #13
AK the Great
Both the shop & dealer said frame was intact and not tweaked whatsoever.
According to the collision shop... when the car goes up on an alignment machine; it can detect any imperfections in the frame. And none were found.
I'll have to inquire about what the alignment looked like when they first did it; and I'll see if they can get me another alignment when they put the aftermarket strut in next Thursday.
I'll see if I can also get a printout of the alignment and post it here.
finch1750 (04-18-2019)
Old 04-18-2019, 11:51 AM   #14
evomike
Drives: frs
wheel alignment machines to not check for unibody structure damage at all, i would take this car to another body shop and have them check it something has to be wrong for it to keep blowing struts. aftermarket struts are not the answer if OEM parts keep failing.
evomike is offline   Reply With Quote
The Following User Says Thank You to evomike For This Useful Post:
blown, collision, curb, problem, strut
Front end out of alignment after going over a curb SamtheKorean Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-16-2019 07:52 PM
A bunch of dash lights are on after curb impact Shadow8948 Issues | Warranty | Recalls / TSB 17 10-28-2014 05:57 PM
curb rash on front lip ! tnt Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 08-08-2013 07:22 AM
Front Lip Curb Rash PecanSandies Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 07-09-2012 03:53 PM
