Drives: frs
how much POG oil to put into AC after condenser replacement
Hey all,
I had a hole in my condenser, so i replaced the condenser. How much POG oil do i add? Dealership tried to suck up all the freon but said there wasn't any left because of the hole in the condenser. Haven't used ac during winter, except window defrosting. |
[insert cool phrase here]
Drives: BRZ Premium
Well, since yours had a hole, I would either buy two big bottles of ac recharge. At the local auto parts store. It doesn't take a whole lot but I'm no mechanic. Also they have a cool little filler gauge that tells you if you need more or less
But since you didn't mention any diy or know of said ac refills I would recommend you take it to a pro ac place have them top you off.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#3 | |
#4 | |
Drives: frs
#5 | |
Drives: 1996 ST204, Series 10 FR-S
In the case of the OP, it definitely needs vacuum for a while to draw out any moisture and air inside his system and he knows that. I have done this a few times but have never found a definite answer because no one really knows. Since you probably lost PAG oil through the following: 1. hole in your condenser releasing all of your refrigerant/vaporized oil. 2. oil physically in your old condenser that you will toss. My guess is that you probably lost half of the oil in your system. I think it would be more harmful to have too little compared to too much. I'd put 50-70% of the factory fill in the system |
It is unusual to loose all the oil with a leak, better parts stores sell small cans of oil Freon mix to add some back to the system. The cans say to add one can to a discharged system. The cans come in different colors to match the oil in the system. I am not sure if there is a difference in the oil by color , but I use the same color. If you have a large compressor you can use an air driven vacuum like the one from Harbor freight. You will need a gauge set with three lines to do it properly. A vacuum pump is better but costs a lot more.
Drives: frs
i got compressor and gauges loaned from autozone.
Got a bottle of r134a and POG 46 (7oz). I'm just gonna go ahead and put half of the bottle. |
You should put the system under vacuum for at least 30 min. The humidity and air in the system right now will cause problems/corrosion later on.
Also any air in the system will overwork the AC pump. Paying ~$100-150 for a A/C recharge is well worth it in my opinion because the machine does a much better job. |
#9 | |
Drives: frs
#10 |
#11 |
Benz Tech
Drives: 2017 BRZ Premium
I have never put more than 2oz in an AC system. 0.5oz is now the way we go. 4oz is a lot of dye, 2 of the single use bottles.
#12 |
Remember the small cans are a mix of Freon and oil, not all oil. Usually delivered to the system slowly and inverted.
#13 |
Drives: frs
#14 |
Drives: frs
| WTB: A/C Condenser | SmireyFase | Want-To-Buy Requests | 1 | 05-16-2017 08:28 PM |
| AC Condenser | MicheleAbbate | Engine, Exhaust, Bolt-Ons | 1 | 05-17-2016 07:11 PM |
| FS: OEM AC Condenser and lines | MicheleAbbate | Engine, Exhaust, Bolt-Ons | 7 | 09-26-2014 02:16 PM |
| WTB: A/C Condenser | 86_ZN6 | Engine, Exhaust, Bolt-Ons | 13 | 08-21-2013 09:26 AM |
| Wtb a/c condenser | CivicEx13 | Want-To-Buy Requests | 0 | 08-12-2013 05:43 PM |
