Drives: '17 MT 86
Swap OEM wheels for an Alignment?
Going to install Tein Flex Zs in the coming weeks. Obviously going to need an alignment. I have no experience with any shops in the GTA but i was looking at apex motoring so far. To be safe in terms of scratching wheels, it shouldn't be a problem using my stock wheels for the alignment and then swapping my rpf1s on after right? Or should i just use the nice set to get the perfect fitment right then and there?
Also if i could have input on what i want specification wise, im looking to do a 1 - 1.25 inch drop. Based on what i read i can expect around -2.2 degrees natural camber in the rear, i dont have any other suspension mods so would the factory toe links be able to bring the toe to 0? Im also planning on doing 0.5 degree more negative than rear for front camber (so approx. -2.7). 0 toe for fronts as well. Does this sound like a reasonable request for an alignment? Much appreciated. |
Drives: 2013 SWP BRZ
Align with the RPF1s and put more camber in the front than the rear if you don't want them even. You may or may not need more toe adjustment but you'll probably be fine with the stock arms. Rear control arms would be a good idea.
Drives: 17 BRZ Series.Yellow
I would recommend a little toe in for the rear. Doesn't have to be much, but I'd do a little because on compression it's going to toe out.
Sent from my Pixel 3 using Tapatalk |
| New wheels/tires=alignment | X Factor | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-14-2015 08:20 PM |
| Wheels & Alignment - Plano | Onikudaki | Southwest | 6 | 09-12-2014 09:43 PM |
| Question about balancing/alignment on new wheels | The_Societan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-23-2013 10:42 PM |
| Wider wheels: need an alignment? | OakmanSmalls | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 07-18-2013 10:34 AM |
