Old 04-11-2019, 12:37 AM   #1
Daisukee94
Drives: soon to be 86
Glitchy ECM problem? CEL P0018
Long Time lurker. Any advice is appreciated.
Need advice on a CEL P0018
this code intermittently came and went after oil changes before, now it's consistently on.
Pic is of TIS scan of Initial VVT learning values. VVT #2 is out of range by 10ish degrees
car : 2013 FRS 38K
no engine mods. basic catback exhaust.
Engine runs fine. idle great. drives smooth. leads me to think it's not a timing issue.
Things I've tried so far.
tried running different oil weights as well.
swap and replaced the crankshaft position sensor.
swap and replace OCV.
haven't swapped ecu or pulled timing cover to check (i probably should but wanted to see if flashing would fix it first).
I read flashing it may make it relearn the initial position values.
If i flash with an OFT will it make the ecu relearn the values?
Daisukee94 is offline   Reply With Quote
Old 04-11-2019, 01:35 AM   #2
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
How is your oil pressure? Does the oil look clear or is it foamy? Just a shot in the dark but you mentioned that it did it after oil changes. VVT works on oil pressure. Maybe you have a problem with your oiling system.
sly is offline   Reply With Quote
Old 04-11-2019, 01:53 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
https://www.ft86club.com/forums/showthread.php?t=123459
Old 04-11-2019, 03:24 AM   #4
Daisukee94
Thanks for your fast responses.
Sly: i don't have a oil pressure sensor so i not sure. But oil doesn't look foamy just looks like fresh oil (after oil change), prior to oil change looked like any other old oil. no odd smells to it either from what i recall.
Ultramaroon: I did play with the value of bank 2 like a couple of pushes out of curiosity but didnt notice any crunchy. but I didn't pay much attention to it. I'll look further into it and feel out the other side to compare.
I'm like 20 pages into the post you link, It's been an emotional roller coaster. @ page 15 i was devasted in thinking i'd have to replace sprocket, then by 20 it's like maybe flashing an ecu will fix it. But i'm optimistic, I'll try reflashing ecu first.
Is a cheapo Tactrix just any J2534 cable (same cable i used with techstream)? Can I use this cable to flash/update my ecu?
Old 04-11-2019, 04:56 AM   #5
steve99
Reflashinv wont fix your problem its a hardware issue
Condsidering that you swapped position sendors and ocv, that leaves the ecu or the actual cam actuators.
Be heaps easier and cheaper to swap in spare ecu. Then onky rearly actuators left which means engine dissassembly
Old 04-11-2019, 10:37 PM   #6
Daisukee94
So i'm not sure i fully understand. Reflashing the current ecm won't work because of the code? shouldn't reflashing the ecm erase that code?
I've also read your guide on how to flash the ecm here
It doesn't mention if you can mix and match. I assume it's all the same since same part numbers. and picked up a dirt cheap used ecm just now.
If i throw a 2013 brz ecm into the 2013 frs would i have to deal with the immobilizer?
Old 04-12-2019, 01:49 AM   #7
steve99
Reflashing will clear cel codes and learned parameters, but if ecu has actual harware fault on the input\output channels for the cam sensors or ocv control signals then reflashing wont fix that.
You can use any model ecu hardware all the same but you may need to flash ecu with a compatavle calibration id\tune to get car to start
Ecu swap proceedure i wrote up here
http://www.ft86club.com/forums/showthread.php?t=102810
Old 04-12-2019, 02:19 AM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
My 2013 FRS has this problem which is why I ditched it. Changed the OCV and swapped the sensors and did not do a thing. Ended up needing a new sprocket and EFU. The P0018 code was soft coded into the ECU and wouldn’t go away. Even after the hardware was fixed, still had ECU issue.
It’s not the actual sensor, it’s the Sprocket. If you love this car, change all 4. I changed one and sold the car with the possibility of 3 sprockets going bad. This was recommended by the dealer as the engine needs to come out anyways. Might as well only do it once.
p0018 oft
CEL P0018 Cams woode Issues | Warranty | Recalls / TSB 69 05-13-2023 03:23 PM
P0018 Problems osudoc11 Issues | Warranty | Recalls / TSB 54 04-10-2018 11:54 PM
P0018 - what a disappointment this car has become Boofneenee Issues | Warranty | Recalls / TSB 96 05-04-2017 03:18 PM
CEL P0018 brichard0625 Issues | Warranty | Recalls / TSB 8 02-10-2016 10:44 PM
31k miles and P0018 happens... MisterSheep Issues | Warranty | Recalls / TSB 65 01-18-2016 06:33 PM
