Old 04-06-2019, 07:51 PM   #1
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Tighten strut nut without shaft spinning?
Has anyone had any experience tightening a strut nut that doesn’t have an allen key opening at the top? Most I’ve seen either have a slot or an Allen key opening, but this set a friend of mine bought for his car has nothing like that, it’s essentially a 6 point bolt head. The problem is it’s basically impossible to hold that still and also use a torque wrench for the actual nut.
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 04-06-2019, 08:36 PM   #2
ls1ac
ls1ac's Avatar
Use a crow foot on the torque wrench, read how to compensate for offset.
Old 04-06-2019, 10:56 PM   #3
Grady
Grady's Avatar
Impact, low setting listen for when it snugs down you do not want to bank on it and overtouqe it.
Old 04-06-2019, 10:57 PM   #4
BFIFE22
BFIFE22's Avatar
Thank you for the advice! This would've worked perfect, however VW/Audi top nuts go into a recessed area where the crow foot won't grip it. They have to make it more complicated as usual. Makes you appreciate how simple the BRZ is to work on. I tried asking for help on a VW forum before here, but you have to wait a certain amount of time after creating an account before you can post.
Going to harbor freight tomorrow, hoping to find a pass through wrench that will allow a 10mm deep socket to pass though, and we should be good if so!
Old 04-06-2019, 11:26 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
Pass through is the ticket. I think the set I have is by GearWrench.
Old 04-07-2019, 02:09 AM   #6
maslin
Benz Tech
Drives: 2017 BRZ Premium
Strut nut socket and an open end wrench on the shaft.
Special strut tools are nice to have around, although rarely used.
maslin is offline   Reply With Quote
Old 04-07-2019, 10:46 AM   #7
BFIFE22
BFIFE22's Avatar
Turns out a 7/8" O2 sensor socket fits around the 22mm nut and has an opening to pass through a 1/4" drive extension which allows me to grip the top of the shaft.
Thank you for the ideas everyone!
ABS and traction light on after spinning out... Seiryuu BRZ First-Gen (2012+) — General Topics 13 02-26-2019 10:42 AM
Tighten my LCAs in the Air Deorio Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-15-2018 10:28 PM
Drive Shaft Shop CF Drive Shaft BNIB (Auto trans) Lefty-FRS Transmission and Driveline 13 02-09-2018 11:02 PM
How to tighten handbrake? Ocean-Grown 86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2014 01:07 PM
Spinning at Buttonwillow (1CW) ddeflyer Tracking / Autocross / HPDE / Drifting 76 05-22-2014 09:24 PM
