Drives: 2014 White FRS
FRS vs 86 Stock Clutch
Hi,
I have a 2014 FRS manual transmission with stock clutch After having a chance to drive a brand new Manual Transmission Toyota 86 from the dealership, I notice the clutch feels way lighter compared to my FRS? Is this normal or does my clutch have problems Car is at 76k km Thank you |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Do you still have the clutch return spring installed?
not playing cards
The throwout bearing starts to hang up on the quill as it galls. They are replaceable. @Tcoat knows what I mean.
You're about at that point in your mileage. Clutch work is expensive but worth the peace of mind.
Drives: 2013 FR-S Series 10
Yep, clutch gets heavier as tob wears. Clutch wear itself also causes a bit heavier clutch. Maybe fresh fluid makes a difference too.
| If my stock clutch is about to go out should I replace it with a stock or a stage 1? | Bread1 | Engine, Exhaust, Transmission | 6 | 01-28-2018 01:24 AM |
| FS: Stock brake lines, stock clutch line, stock motor mounts | Agent_D | Brakes, Suspension, Chassis | 4 | 08-22-2017 12:24 PM |
| FS: Stock Clutch | Germanjap | Transmission and Driveline | 1 | 09-19-2015 02:37 PM |
| ACT clutch and LWF or stock clutch and Evolution industries LWF | Hawk77FT | Engine, Exhaust, Transmission | 13 | 12-21-2014 02:14 AM |
| Stock clutch $50 obo | PineappleFriedRice | Transmission and Driveline | 2 | 11-25-2013 01:21 PM |
