Southern California SoCal
Old 03-23-2019, 07:29 PM   #1
Dadajair
Dadajair's Avatar
Drives: 2014 Scion FR-S
Thermal Barrier Coating Ceramic Coating for Exhaust and More
Hey guys just wanted to put the word out there for anyone interested in exhaust heat management for their ride. My shop here in San Diego offers this service your your headers ,turbo casing , and anything else you may want to get ceramic coating.
Thermal barrier ceramic coatings are becoming more common in automotive applications. They are specifically designed to reduce heat loss from engine exhaust system components including exhaust manifolds, turbocharger casings, exhaust headers, downpipes and tailpipes. This process is also known as "exhaust heat management". When used under-bonnet, these have the positive effect of reducing engine bay temperatures, therefore reducing the intake air temperature.
Although most ceramic coatings are applied to metallic parts directly related to the engine exhaust system, technological advances now allow thermal barrier coatings to be applied via plasma spray onto composite materials. It is now commonplace to find ceramic-coated components in modern engines and on high-performance components in race series such as Formula 1. As well as providing thermal protection, these coatings are also used to prevent physical degradation of the composite material due to friction. This is possible because the ceramic material bonds with the composite (instead of merely sticking on the surface with paint), thereby forming a tough coating that doesn't chip or flake easily.
Although thermal barrier coatings have been applied to the insides of exhaust system components, problems have been encountered because of the difficulty in preparing the internal surface prior to coating.
Dadajair is offline   Reply With Quote
The Following User Says Thank You to Dadajair For This Useful Post:
MJones_RB (03-26-2019)
Old 03-25-2019, 12:49 PM   #2
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
where are you located and name of shop? I do need to get my turbo coated.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 03-25-2019, 10:09 PM   #3
Dadajair
Dadajair's Avatar
Mission valley area, Called Flame Spray Inc. I'm the thermal spray lab tech . I do the destructive testing and microanalysis.
JDL UEL w/ cat and thermal coating [SOCAL] thebigcheese Engine, Exhaust, Bolt-Ons 1 03-02-2018 03:19 AM
Ceramic Thermal Coating on Flanges of ACE Header? RJasonKlein Engine, Exhaust, Transmission 14 08-21-2016 06:35 AM
Thermal Coating OP/FP? Scuba86 Engine, Exhaust, Transmission 4 11-24-2015 12:52 AM
ceramic coating eddiev116 NY / NJ / CT / PA 3 02-06-2015 05:54 PM
Ceramic Coating options or Jet hot coating brzadmir NY / NJ / CT / PA 4 07-10-2013 12:35 PM
