Old 03-22-2019, 06:39 PM   #1
Nevinyrral
Drives: BRZ '16 Limited AT
2016 Subaru Head Unit Screen Black
Hello guys,
was wondering if anyone had any suggestions on fixing my semi-dead head unit. Randomly the other day I was swapping to reverse which is suppose to trigger the back up camera on the head unit but it just turned black and never turned on again. The radio still works as my bluetooth is autoplaying my phone's music when it is on.
The subaru local mechanic i went to doesnt touch radios and a guy that does stereos suggested unplugging and replugging the battery (did not work). Has anyone had this issue? Is this a bad wire? Do I need to pull the head unit out to check? Would it be easy to fix myself? Also I don't think its the fuse since i swapped the radio fuse with the spare unless theres more fuses connected to the head unit...
Should i just bring it to the dealer?
Thanks guys!
Nevinyrral is offline   Reply With Quote
Old 03-26-2019, 09:44 AM   #2
Racecomp Engineering
Is your car still under warranty?
- Andrew
Old 03-31-2019, 07:34 PM   #3
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
Does the screen show the start up logo when you first turn on the car?
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
FS: 2017 OEM Touch Screen Head unit rva_86 Audio/Visual, Electronics, Infotainment, NAV 12 08-06-2019 08:01 AM
Radio/Nav head unit is stuck on blank screen ItsEddyG Electronics | Audio | NAV | Infotainment 6 06-16-2018 01:34 PM
Head Unit Screen Malfunction LilGreenNumbers Electronics | Audio | NAV | Infotainment 1 03-17-2018 12:32 AM
head unit screen cracked flat486 Issues | Warranty | Recalls / TSB 5 01-15-2016 12:44 AM
Scion touch screen head unit from FR-S geezer86 Audio/Visual, Electronics, Infotainment, NAV 9 10-03-2014 10:28 PM
