Old 03-22-2019, 09:22 AM   #1
Victini
Drives: 2012 Toyota 86 GTS (Orange)
AVO Stage 2 vs Stage 3 Kit
Hey guys, I was going to get a Stage 3 AVO turbo kit for my 86 but ran into some confusion. I have been trying to figure out the difference between stage 2 and stage 3 turbo's and I am under the impression it's just a billet turbo that is rated for better flow? Can someone please confirm this for me. Also I am thinking of running low boost numbers as I am running on a stock engine. Would it be possible to tune it for flex fuel with boost varying from 8psi up to 13psi (using a GFB electronic boost controller)?
Also a very big confusion is what the car would feel like (in terms of spool time and where power comes on) in comparison to a stage 1 or 2 avo turbo. I only have this confusion as the kits have the same turbo but stage 3 is "billet". I am aiming at getting increased power but still have boost coming on as early as the other kit's turbos.
Victini is offline   Reply With Quote
Old 04-06-2019, 10:00 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
You're right "stage 3" is just an upgraded billet compressor wheel.
Throughout the years, the different stages of the AVO kit have changed. Last I heard, the stage 1 has a 5-7 psi spring. The stage 2 comes with an 8psi spring and a catch can.
With an electronic boost controller you can run double the pressure of the spring in boost. So a 8 psi spring can run up to 16 psi of boost.
tyler_win_photo is offline   Reply With Quote
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
FRS single stage vs dual stage driver's airbag mhiscott Issues | Warranty | Recalls / TSB 2 09-23-2017 03:43 PM
Innovate Stage 1 Supercharger with stage 2 accessories azynneo Engine, Exhaust, Bolt-Ons 3 08-30-2016 12:32 AM
Exedy Stage 1 Failure: Advice + Stage 2 Questions Pneub Engine, Exhaust, Transmission 4 07-18-2016 09:24 PM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 10:16 PM
