Old 03-21-2019, 10:12 PM   #1
geraldjust
Drives: MR2, Sliver BRZ
ULTIMATE RADIO WIRING GUIDE
HEY guys! ive recently got a new android head unit and ive been trying to find the best wiring diagram as possible but so far everything pointing me in different directions. So i think i need some of your guys help to try and identify the different kinds of wiring all cars have.
For all cars it seems that the power connector and the speaker connector seems the same (6 pin and 10 pin).
But what differs from year to year, trim to trim , brz to frs is the 28 pin, 24 pin, 20pin and the 16 pin connectors.
Along with a extra connecting hanging out in the back of the area.
SO! if your looking for adapters here is the list i started piling up!
SMA connector to Factory GPS antenna
https://car-solutions.com/en/adapter...baru-mazda.php
OR...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For Antenna adapter this good ol works just fine:
So do you think you guys can contribute with your year, model and trim and a picture of your guys connectors?
For example:
My car is a 2015 limited model
I have:
2 GPS connectors??
28 pin connector
16 pin connector
antenna connector
6pin +10 pin connector
a extra 6pin connector similar to the audio one above
4 pin connector for USB
I do have the wiring diagram for the frs-13, the brz-13, and gt86-17.
So could i get some help form you guys trying to the setup of you guys that would help me out tryin to make a ultimate guide!
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 03-27-2019, 09:37 PM   #2
geraldjust
All right for anyone who is interested like i am in finding all the connectors manufacturers to try in the future to make plug and play connectors.
Found out the connector for the USB port!
MX49004HQ1
is the part number for the though hole version for those out there with PCB making experience.
edit:
GPS antenna is 6098-2724
HFC series connector from Sumitomo
Old 01-13-2022, 01:22 PM   #3
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
I was able to install a 2018 Radio (low spec radio, not the one with Android Auto/Car Play) in my 2013 BRZ. I had to move a few leads on the 28 pin connector and it all seemed to work fine, except the GPS and Satellite antenna connectors changed, but I use my phone for GPS and don't use Satellite radio.
I've got a 2020 radio with Android Auto/Car Play and i'm trying to get that installed. I hooked it up and I got an Antenna error issue, so I really need to figure out the antenna leads. I'm hoping to get your OEM to SMA adapter to work and then I just need to get SMA connectors on the leads to took with the radio.
G_Rossney is offline   Reply With Quote
Old 01-13-2022, 01:25 PM   #4
G_Rossney
https://photos.google.com/album/AF1Q...q_7-VLbvQF1qzp
Need to figure out how to connect convert from the green connector to the Blue connector.
Ultimate guide for Airlift Front wheel fitment vs Double Bellow Bag/CUP system raytrix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 87 09-02-2020 08:17 PM
Spyder Headlight install wiring guide. sk900 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-05-2018 09:54 PM
DSport Ultimate Tuning Guide jenzan BRZ First-Gen (2012+) — General Topics 11 04-18-2017 05:24 PM
Radio Wiring Harness Razzle AFRICA 4 06-23-2014 04:21 PM
WTB: Radio wiring harnesses/adaptors JonA Audio/Visual, Electronics, Infotainment, NAV 6 04-08-2013 12:24 AM
