Drives: 2014 Scion FR-S
Rattling sound coming from Brake booster and Master Cylinder
Ok, so here goes.....
Earlier in the week I posted a thread about a knocking/rattling sound coming from the engine bay of my 2014 FRS Automatic when at a full stop with the brakes applied in drive. Not in Park, Neutral, or reverse. After much searching around to include looking for loose heat shields I could not find anything out of the ordinary. Long story short I went to Harbor Freight and picked up a stethoscope (my old one broke) and was able to replicate the conditions in my driveway with my friend driving the car and stopping so I could get out and see if I could track down the sound. My first suspicion was the secondary vacuum pump but it sounded normal. On a whim I moved over to the master cylinder and with the stethoscope probe plain as day I was able to hear the rattling sound coming from the master cylinder and to a lesser extent the brake booster. Also, pumping the brakes hard causes the same symptom but with a dip in RPM's that recovers quite quickly. Also I would add that the brakes feel perfectly fine with no symptoms other than the sound. Any Idea what could be causing a knocking/rattling/high pitched squeaking sound from a master cylinder or brake booster? A bad check valve? A vacuum leak? Or bad cylinder or booster? I'm stumped. I'm going to investigate further but wouldn't mind some opinions. |
| FS: OEM Brake Booster Master Cylinder (MT) | MicheleAbbate | Brakes, Suspension, Chassis | 17 | 05-14-2020 03:36 PM |
| RCE Swaybars, Radium Brake Master Cylinder Brace, GT3 brake ducts | airindia33 | Brakes, Suspension, Chassis | 3 | 03-27-2018 08:48 PM |
| Master brake cylinder brace | Carmaniac 86 | Brakes, Suspension, Chassis | 2 | 08-02-2017 08:40 PM |
| WTB Brake Master Cylinder brace | tracerit | Want-To-Buy Requests | 4 | 04-03-2016 01:13 AM |
| BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC | SOURCE,LLC | Brakes, Suspension, Chassis | 94 | 07-07-2013 10:56 PM |
