Drives: 2013 FRS
FI Automatic Exhaust Questions
Hi all, I am planning on getting the JDL turbo kit with recirculated wastegate, and want to ensure I have plenty of exhaust diameter to support it. My plan was to get a 3" overpipe and frontpipe, then a 2.5" catback, assuming that wouldn't be a bottleneck for my 300whp goal.
I was looking at getting the JDL OP/FP combo, but the site says the 3" option won't fit with an automatic transmission. My questions are: -Am I out of luck for a 3" OP/FP with AT? It seems there are very limited 3" options - the only other one I could find was the nameless overpipe and frontpipe combo, but that also supposedly won't work with AT. -Is 3" even necessary for this setup? Based on what I've found online, it looks like a 2.75"-3.00" diameter is recommended for that power goal, and I figured it'd be better to go larger due to the recirculated wastegate and catted FP. Any help is appreciated. Thanks in advance. |
Drives: Bone stock
Maybe the nameless 3" can fit or get it on custom made.
Sent from my SM-N960U using Tapatalk |
Drives: FRS
2.5 is fp/op is good enough unless you're aiming for 450whp+ the biggest bottleneck are the catalytic converters.. also if you go 3" fp op you will have metal on metal contact due to rough fitment causing false knock.. my setup is 2.5 fp op into 3 inch cat back has no issues
I hit 360whp on a stock exhaust with stock diameter piping all the way back, with a stock front pipe.
I don't think you need to worry! |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
Rust bucket enthusiast
If you want to be sure you hit the goal, ditch the standard pte and go with the upgraded Garrett turbo options.
Edit:: 86speed has a sale right now on the UEL kit with the 2860rs, you'll have no problem getting 300whp with this setup. Comes recirc, too. https://www.86speed.com/jdl-turbo-kit-2860rs-spec-kit |
#7 | |
Drives: 2013 FRS
Thanks for the replies, everyone. After additional research, I decided to go with the Tanabe 2.5" OP and JDL 2.5" ultra-quiet FP.
Unfortunately I'd like EL headers so not sure that sale will be an option, but I'll reach out to JDL.
| Exhaust Set-Up Questions | Anderzz | Engine, Exhaust, Transmission | 5 | 08-26-2016 03:17 PM |
| Automatic Transmission Exhaust Sound (Greddy SP Elite) | DGM-BRZ | Engine, Exhaust, Transmission | 2 | 05-25-2016 12:14 PM |
| Exhaust Questions! | Bjeoen | Engine, Exhaust, Transmission | 3 | 12-02-2015 12:21 AM |
| Exhaust Questions? | 636 | Engine, Exhaust, Transmission | 6 | 10-19-2013 04:14 PM |
| difference in exhaust for automatic vs manual? | agoodcar | Engine, Exhaust, Transmission | 4 | 10-27-2012 03:19 PM |
