Old 02-27-2019, 10:34 AM   #1
msaikhan
Drives: frs
Throw out bearing + clutch questions
2013 frs 120k DD occasional hard driving
stock engine
Been hearing whining noise on cold start up, looks like throw out bearing from searching on the forum.
Looking at exedy stage 1 clutch kit,
turbo/ super charger down the road maybe.
Going to replace it myself, hopefully.
Getting a list together to do the job.
Questions.
Do i need to upgrade clutch fork or flywheel or anything else? Is the exedy pressure plate has same amount of pressure as stock?
thanks.
msaikhan is offline   Reply With Quote
Old 04-27-2019, 12:04 PM   #2
KingJon1991
Drives: scion frs 2015
the oem clutch and flywheel is exedy if you have no new flywheel your going to have to get the oem one resurfaced
KingJon1991 is offline   Reply With Quote
Old 04-27-2019, 01:45 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
stock engine
Questions.
thanks.
The Exedy Stage 1 is the OEM kit with a stiffer pressure plate (same clutch plate). I don’t think they have upgraded the TOB yet, so you will want that. You will need to resurface the flywheel. I think it would be worth it to upgrade the clutch and pivot. That is what I did. I also replaced my snout/snorkel. See my build.
Old 04-27-2019, 06:06 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If the fork and flywheel do not show signs of abuse it's not needed.
As for the flywheel it depends if there is no pitting or grooves and the clutch was not worn the fuck out, you can skip the flywheel resurface.
But, if you want to and got the money for it go for it.
When my TOB died I only replaced the TOB. flywheel and fork look good for 70k miles. Zero problems daily driving since then.
Old 04-27-2019, 07:13 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Not resurfacing is a quick way to burn 5Kmi off of your brand new disc.
I'm pulling that number out of my ass but you get what I mean from a best-case perspective. Worth it? iono
Old 04-27-2019, 07:56 PM   #6
Irace86.2.0
It is like $50 to resurface.
The OEM fork is weak and has been known to fail on OEM equipment. Add the increased pressure of a Stage1 pressure plate and that could be bad. Just saying.
Old 04-29-2019, 04:18 AM   #7
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Need to? No. Should you? Yes.
Get one of these:
https://www.ft86speedfactory.com/ver...2013-ft86.html
and don't forget this as well:
https://www.ft86speedfactory.com/vel...2013-ft86.html
You already have the transmission out so while you're at it you can do the job properly. If nothing else the difference in feel was worth the price for me and a quick search on these forums shows great reviews for the fork.
clutch
Squeaking Clutch Noises NOT Related to the Throw Out Bearing BigTuna Issues | Warranty | Recalls / TSB 13 09-27-2018 02:32 AM
Throw out bearing Hyp Northern California 26 03-13-2017 11:42 PM
Repair shop in LA - Clutch Throw out bearing Octoman Southern California 18 09-06-2016 04:45 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
FS: NJ O.E.M. Clutch, flywheel, throw out bearing Michaeljp92 Transmission and Driveline 9 02-03-2014 11:42 PM
