Old 02-23-2019, 04:30 AM   #1
hayuk
Drives: Toyota GT86
Wierd noises from sprintex supercharger
Hi
New here
I have 2012 toyota gt86 with sprintex kit on it. I bought it with the kit on it and ever since then the engine bay make squeaking noises , probably belt/pulley noises.
First inspection showed that the accessory belt tensioner was not working right so he got replaced with a new one, but the noise is still there.
Ill try tomorrow changing the drive belt since i have a spare one at my garage, but she looks perfect, no signs for cracks or anything.
Im starting to think the noise is from the sc pulley , is it possible to oil him a lil bit ? Mabey he making this squeaking noises?
Does anyone faced the same problem ?
Thanks.
hayuk is offline   Reply With Quote
Old 02-24-2019, 12:23 AM   #2
Yeet
Drives: 2013 FRS
Have you changed the gear oil in the supercharger itself in the time that you've owned the car?
Yeet is offline   Reply With Quote
Old 02-24-2019, 02:57 AM   #3
hayuk
Drives: Toyota GT86
Well no i didn’t.
Actually didn’t know there is oil in the supercharger ..
Where can i get some info about this ?
Old 02-24-2019, 11:15 AM   #4
hayuk
Drives: Toyota GT86
So i did some research and bought redline 75w90 ns gear oil , changed the sprintex oil that was almost empty !
Changed the drive belt also , and now everything seems to work perfect. No noises at all.
Thanks !
Old 02-24-2019, 11:30 AM   #5
Yeet
Drives: 2013 FRS
No problem! Glad you found the issue before anything went wrong! enjoy your car
Old 02-24-2019, 11:35 AM   #6
HaXx
Drives: jrsc_brz
yeah the rotrex blower in the jrsc kit tends to eat oil too. everyone says the service interval for the blowers oil change is 50k miles or 2 years, im like no way in hell dude. 10k miles.
HaXx is offline   Reply With Quote
Old 02-24-2019, 08:28 PM   #7
jflogerzi
jflogerzi's Avatar
Sprintex kits are every 30k but when pushed I have read the seem to loose a bit oil. Most people recommend checking the oil level regularly and it must be jacked up to to get a level reading.
2013 Series 10 FRS #553
Old 01-15-2020, 03:00 AM   #8
86driftcar
86driftcar's Avatar
Mine is making weird noises too. Ive attached a video which distinctively demonstrates the sound I'm referring to. I haven't gone to a shop to have it looked at yet but Im thinking this a pulley bearing on its way out (not sure which one)
This noise completely goes away once the car is warmed up. Does anyone know what this could possibly be?
[ame]https://www.youtube.com/watch?v=8_DGa2WWJ2U[/ame]
86driftcar is offline   Reply With Quote
Old 01-16-2020, 01:55 AM   #9
jflogerzi
jflogerzi's Avatar
Are you talking about that squeak? If so it's the belt. What pulley do you have? Mine did that for a bit after I switched to the 69mm from the 72.5 but it's gone away. Get a spray bottle of water and use to lightly spray the belt. If the sound goes away might want to put a fresh belt.
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
86driftcar (01-18-2020), Ultramaroon (01-19-2020)
Old 01-18-2020, 04:35 AM   #10
86driftcar
86driftcar's Avatar
Hey thanks for the reply
Yes I'm referring to that squeak lol
I'm running the 69mm pulley since I had the SC install. I just got this supercharger + pulley/belt a few months ago. Is it possible I need a new belt already. I dont track the car... just daily drive it and occasional pulls nothing crazy. It's hard to believe I need a new belt already but I will try your suggestion.
Old 01-18-2020, 09:58 AM   #11
jflogerzi
jflogerzi's Avatar
What idler pulley are you using?
Old 01-18-2020, 03:36 PM   #12
86driftcar
86driftcar's Avatar
I'm still using the OEM idler pulley.
Old 01-18-2020, 04:42 PM   #13
jflogerzi
jflogerzi's Avatar
Dorman 419-610 Idler Pulley https://www.amazon.com/dp/B003QVIXYU..._yT3iEbDB97W6J
Try this. The stock one will not work as you drop the down to smaller sc pulleys
86driftcar (01-19-2020), JDM_Import (01-19-2020)
Old 01-18-2020, 07:24 PM   #14
whataboutbob
AutoX-10/10ths every run
I ran one of these kits for 62K miles. I'd recommend checking the gear oil in the blower on a very regular basis, it will consume oil and if it goes dry bad things will happen.
Build thread:Here
The Following 3 Users Say Thank You to whataboutbob For This Useful Post:
86driftcar (01-19-2020), JDM_Import (01-19-2020), wparsons (01-30-2020)
Sprintex 210 Supercharger + Intercooler Kit R2RO Engine, Exhaust, Bolt-Ons 24 09-03-2018 09:46 PM
Sprintex Supercharger Jakebowles Engine, Exhaust, Bolt-Ons 1 08-11-2016 02:24 PM
Sprintex Supercharger Group BUY! Xero-Limit Groupbuys 44 02-14-2015 03:13 PM
RMS Sprintex Supercharger for sale Ryan86 AFRICA 5 12-16-2014 12:59 PM
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
