Old 02-19-2019, 01:50 AM   #1
Turbo
Drives: FR-S Turbo
ACT throwout bearing - use or discard?
I have an ACT 6-puck clutch kit (with lightweight flywheel) going in soon. Will also be installing a Verus fork & pivot at the same time.
Now the million $$ question - should I use the T.O.B. supplied by ACT for the install, or the "new" design OEM one?
What is everyone's experience with this?
** bonus question - my kit is enroute. Does it come with a metal install tool (as I've been told I need) or will I need to source one?
Turbo is offline   Reply With Quote
Old 02-19-2019, 02:21 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If it was me, I would go with the new updated TOB. its only like $50 depends where you get it.
Metal install kit, hum.... must be the clutch alignment tool. All clutches come with that. If not they are like $2 at any auto parts store. Or you get them for free depends how pitiful you look when you ask.
The Following User Says Thank You to Mr.ac For This Useful Post:
Turbo (02-20-2019)
Old 02-19-2019, 01:42 PM   #3
Turbo
Drives: FR-S Turbo
Correct - I meant clutch alignment tool.
I have researched it online and the ACT domes appear to come with a plastic tool.
Unfortunately, I've also read in various places this tool is problematic as it doesn't center the disc well enough due to poor tolerances and rigidity.
Is the dealer likely to have a metal centering tool or should I search one out on my own?
Old 02-19-2019, 01:47 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
There is no known aftermarket TOB, so it is either the old TOB, or the new white dot TOB. If it isn't the new part, throw it out and get the new one.
Turbo (02-20-2019)
Old 02-19-2019, 07:49 PM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Yes spend more money on a tool that can do the same exact thing as a plastic one can.
the dealership will sell you the same plastic tool.
No ideal where you are getting the poor tolerance thing from. Eh what ever. I'm tired of thinking today.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
fika84 (02-22-2019), Pat (02-20-2019)
Old 02-19-2019, 10:39 PM   #6
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
ACT gives the old TOB with their kits, mine was bought late last year and it had the old one inside the box. I ended up ordering a new one from the dealer.
Trueweltall is offline   Reply With Quote
The Following 2 Users Say Thank You to Trueweltall For This Useful Post:
Pat (02-20-2019), Turbo (02-20-2019)
Old 02-20-2019, 12:23 AM   #7
Turbo
Drives: FR-S Turbo
Thanks, guys. If the clutch doesn't have the new TOB in the box, I will get it through the dealer.
Old 02-20-2019, 06:11 AM   #8
ermax
ermax's Avatar
When you do be sure to get it through Subaru. Toyota wants twice the price for it than Subaru.
The Following User Says Thank You to ermax For This Useful Post:
Turbo (02-20-2019)
Old 02-20-2019, 04:55 PM   #9
Pat
Pat's Avatar
Drives: 2023 BRZ
Yep, I had the ACT Streetlight put in today. I can confirm it came with the old bearing. The one we ordered from Worldpac came with a little divot in it, not a white dot.
The Following User Says Thank You to Pat For This Useful Post:
Turbo (02-20-2019)
Old 02-20-2019, 05:46 PM   #10
TRAKRAVN
Drives: 2015 Scion FRS - Raven
What's the difference between the two, other than the dimple "white dot"?
TRAKRAVN is offline   Reply With Quote
Old 02-20-2019, 06:31 PM   #11
ermax
ermax's Avatar
Internal lubricant. The old lubricant couldn’t handle the heat and would dry out and fail.
The Following 2 Users Say Thank You to ermax For This Useful Post:
TRAKRAVN (02-20-2019), Turbo (02-20-2019)
Old 02-20-2019, 06:40 PM   #12
Pat
Pat's Avatar
Drives: 2023 BRZ
Yeah, now I have to figure out what to do with the older version I didn't bother installing.
Old 02-20-2019, 06:48 PM   #13
Grady
Grady's Avatar
Do everyone a favor and throw it in the trash.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Throwout bearing going bad B-R-Z Engine, Exhaust, Transmission 40 09-08-2017 09:23 AM
Throwout bearing. bdanisi Issues | Warranty | Recalls / TSB 54 07-17-2016 06:13 AM
63,000 and throwout bearing ruined everything riironman Issues | Warranty | Recalls / TSB 188 05-14-2016 11:02 AM
Throwout bearing? RavioliG Issues | Warranty | Recalls / TSB 3 10-31-2015 01:17 PM
act throwout bearing blown Engine, Exhaust, Transmission 0 08-30-2015 02:17 AM
