Old 02-14-2019, 04:22 PM   #1
gpvecchi
gpvecchi's Avatar
Trunk strut guide
If you plan to add/change/remove rear spoiler you can come into the problem of trunk becoming too hard/weak to close, as I did.
This is because of the different weight; i.e., I removed 2017+ spoiler to fit a TRD one.
So I made some research, and I'm going to post the results.
Now, all the struts are same sized, so straight swappable; these are the stiffness and the P/N for them.
Toyota:
SU003-07208 305N
SU003-01462 305N
SU003-01463 380N
SU003-07209 380N
SU003-01464 420N
SU003-07210 420N
SU003-06404 520N
Subaru:
57522CA000 305N
57522CA001 305N
57522CA011 380N
57522CA030 520N
305N is without spoiler
380N is with spoiler -2016
420N is with Aero/Nur Spec spoiler
520N is with 2017+ spoiler
To help you find what you need, I'll post the known spoiler weight:
TRD ducktail spoiler (genuine) 700 grams
-2016 spoiler 1500 grams
2017+ spoiler 6000 grams
gpvecchi is offline   Reply With Quote
The Following 12 Users Say Thank You to gpvecchi For This Useful Post:
apatel471 (01-29-2023), Bonburner (10-14-2023), Chimera (02-15-2019), DAEMANO (02-14-2019), EndlessAzure (01-30-2023), Leonardo (02-14-2019), MrSkubi (01-30-2023), sav (04-17-2025), slim blanco (01-31-2023), soundman98 (02-14-2019), TheStig85 (02-02-2021), Trap63 (07-29-2020)
Old 01-28-2023, 06:04 PM   #2
ste65
Drives: 2015 Scion FRS A/T
If you could, may you post the link to the toyota website that has the 420N struts for sale? I can't seem to find it. Thank you!
ste65 is offline   Reply With Quote
Old 01-28-2023, 08:01 PM   #3
whataboutbob
AutoX-10/10ths every run
Not sure if these sites are legit, but here's what I found:
https://www.megazip.net/zapchasti-dl...?shipper=japan
https://www.monotaro.co.th/p/55460834.html
Build thread:Here
Old 01-29-2023, 11:53 AM   #4
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
https://www.amayama.com/en appears to have all of them listed.
villainous_frx is offline   Reply With Quote
Old 01-30-2023, 01:39 AM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
1000 grams ~= 10 N weight
EndlessAzure is offline   Reply With Quote
Old 02-10-2023, 04:11 PM   #6
ayylmao
Drives: 2016 Scion Frs
E7210CA110 is the strut specific to the BRZ ts with the big wing. Not sure on how strong it is but given how big the ts wing is, might be the highest N.
ayylmao is offline   Reply With Quote
The Following User Says Thank You to ayylmao For This Useful Post:
gpvecchi (02-10-2023)
DIY guide for Replacing Trunk Props/Struts leevanf Cosmetic Modification (Interior/Exterior/Lighting) 6 06-25-2018 12:09 AM
FS: CWP BRZ Sporttech trunk + GTSPEC Front strut bar + intake goodies WhiteBRZ4 Canada Classifieds 5 10-02-2016 12:35 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
Trade FRS trunk mat trimmed for Cusco rear strut bar for non modified (SF bay area) serial gixxer Interior Parts (Incl. Lighting) 10 10-15-2013 02:37 PM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:27 AM
