Old 02-12-2019, 06:47 PM   #1
Spectral Entity
Spectral Entity's Avatar
Drives: 16 Scion FR-S Hot Lava, 81 DeLorean
Feeling choked compared to sport mode's free-spirit
I love these cars, so much that after my first one was totalled back in October, I went and found another one!
One thing I've been curious about, in the four years of owning a twin, is what exactly makes the car feel as if it's hindered when accelerating harder when driving at highway speeds in normal mode?
I can put it in sport mode, and the car becomes more responsive to throttle input and holds the gear longer before downshifting, with revs jumping up a bit.
Then when on an incline, when you tap the throttle to downshift, sometimes the car feels downright sluggish in normal mode until it kicks down a gear and picks up speed, whereas in sport mode it's more instantaneous.
Thanks in advance!
Spectral Entity is offline   Reply With Quote
Old 02-12-2019, 07:03 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Feeling choked? You're probably just not in the power band which is really only above 5 K RPMS and since you have an auto tranny, you're at the mercy of the computer trying to recognize the best gear to be in.. Sport mode merely makes the tranny computer more aggressive in downshifting but it ain't got telepathy powers so if you really want to avoid being out of the powerband then you're gonna want to take total control by using M mode or at least keep clicking the downshift paddle until it starts beeping.
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
Spectral Entity (02-13-2019)
Old 02-12-2019, 07:13 PM   #3
Brink
Drives: 2017 BRZ
Auto in normal mode likes to just get into 6th gear and sit somewhere near 2k-2500 RPM where it makes no power and lugs worse than an underpowered 90s minivan. Even after the first forced downshift the RPM doesn't climb enough to make much of it right away. In sport mode you're probably cruising no higher than 5th gear, and more like 3k+ RPM - not in the powerband yet but it's already much more responsive at that point and the first downshift from there will probably take you up around 4k where you're beginning to climb back up out of the torque dip.
Brink is offline   Reply With Quote
The Following User Says Thank You to Brink For This Useful Post:
Old 02-12-2019, 07:16 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Sport mode is more aggressive RPM wise and will shift accordingly. Throttle input, hard braking, etc helps tell the computer what to do. It's for MPG when in normal modes.
And trying to pass someone in 5th or 6th gear isn't gonna get you anywhere except and unhappy motor from the excess load.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
mgarcia707 (02-13-2019), Spectral Entity (02-13-2019)
Old 02-12-2019, 07:19 PM   #5
The normal mode in the AT is set up to get the most mileage with the least emissions possible. It is something they are sort of forced to do to be compliant with the regulations. At least they give you a sport or manual mode that can compensate for that a bit.
Old 02-12-2019, 07:19 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Simple fix, get a manual.
The Following User Says Thank You to Mr.ac For This Useful Post:
Summerwolf (02-13-2019)
Old 02-12-2019, 07:22 PM   #7
SHIT too late
Oh well...
finch1750 (02-13-2019)
Old 02-12-2019, 07:25 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Spectral Entity View Post
I live these cars, so much that after my first one was totalled back in October, I went and found another one!
Thanks in advance!
The only thing that changes between sport and normal on our cars is TCM mapping. That's why it feels more responsive. If you want a serious kick on the auto thats faster than a stock manual get some 4.88 gears to throw in the rear diff
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Spectral Entity (02-13-2019), Tcoat (02-12-2019)
Old 02-12-2019, 09:14 PM   #9
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
keep the RPM 4K up, you ll get all the power you need!
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
Old 02-13-2019, 11:17 AM   #10
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
SHIT too late
Oh well...
Can't wait until the 2nd gen premieres with CVT-only.
bkharmony is offline   Reply With Quote
The Following 2 Users Say Thank You to bkharmony For This Useful Post:
finch1750 (02-13-2019), Tcoat (02-13-2019)
Old 02-13-2019, 02:23 PM   #11
finch1750
finch1750's Avatar
That'll be the trade off for the turbo
bkharmony (02-13-2019), Tcoat (02-13-2019)
Old 02-13-2019, 02:23 PM   #12
Spectral Entity
How does the 4.88 gear make it faster?
I'm legitimately curious; I noticed when playing around in Forza that when messing with the gear ratios, the car can me made slower, quicker, have more mid-range power or overall top speed, depending on the specific ratios.
Old 02-13-2019, 02:30 PM   #13
A higher ratio will give you more toque at the wheels which means the car will accelerate faster but it takes more work from the engine. A lower one will give you a higher top speed but it will take longer to get there. They use a lower ratio to get better mileage since the engine isn't working as hard.
FRSBRZGT86FAN (02-14-2019), Spectral Entity (02-13-2019)
Old 02-13-2019, 02:35 PM   #14
ermax
ermax's Avatar
The same way the MT is faster than the AT. The MT has better gearing. The AT also comes off the line slow but even if you go from a roll the MT is faster due to gearing.
When you are playing Forza there are a lot of variables because you are on a race track as opposed to simply looking at straight line acceleration. On a race track you could have an FD that works well on some corners and not so well on others because of the speeds of the various turns and where your power band is. If all you are changing is the FD then you you have a lot of tradeoffs. This is why fully built race cars don't only make FD adjustments but instead make individual gear changes in addition to FD changes depending on the track.
Even in autox you will have some layouts that work better with pre 2017 gearing, some that work better with post 2017 gearing and some that work best with AT gearing. More often than not it seems pre 2017 gearing works best at autox because 1st ends up being really short and you end up going between 2nd and 3rd a lot more.
The Following 3 Users Say Thank You to ermax For This Useful Post:
FRSBRZGT86FAN (02-14-2019), Spectral Entity (02-14-2019), Tcoat (02-13-2019)
Vsc sport and Sport mode at the same time? Markk Scion FR-S / Toyota 86 GT86 General Forum 22 09-28-2015 03:07 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 03:40 AM
DIY Auto VSC Sport and AT Sport Mode Seattle944t DIY (Do-It-Yourself) Guides 0 09-08-2013 06:02 PM
Cruise control with Sport or VSC Sport mode notout86 Scion FR-S / Toyota 86 GT86 General Forum 12 08-29-2013 07:50 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 12:50 PM
