Drives: 2017 BRZ WR blue PP
RPF1 17X9 +35 with PP Brembo
installed yesterday with 8mm spacers in front and drove back from LA to SB. I inspected two front wheels and there is no sign of any touching or rubbing between calipers and wheels. I don’t know how large should be considered ok for the gap but to me it is not too close and I think this gap should be safe on track. 8mm spacer is the minimum you need to use in front. If you use 10mm spacer the clearance will be more than enough. Here are pictures I took after few hundred miles on them. 35 offset does make them poke out more than I thought.
Drives: 2017 BRZ PP
Looks good. You spaced out the rears too?
Drives: 2017 Subaru BRZ PP
Spacers
I'm thinking of doing the same to my BRZ once I have enough cash. Did you need to cut the lugs at all to make the spacers fit? And which spacers are those? Thanks.
-Alex |
| ENKEI RPF1 Bronze, Gunmetal & Gold 17x9 35mm, Team Dynamic PR1.2 17x9 35mm @OAKOS | OAKOS Automotive | Groupbuys | 138 | 08-09-2018 05:14 PM |
| ENKEI RPF1 in 17x9 +35 & Team Dynamics PR 1.2 17x9 +35. PM for FORUM PRICE! | OAKOS Automotive | Groupbuys | 145 | 12-14-2016 02:54 PM |
| 17x9 or 9.5 that cleared Sti brembo | Vten | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 12-22-2014 10:10 PM |
| Help : Enkei RPF1 Clear STi Brembo's?? | yoonjin | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 10-19-2014 11:45 AM |
| Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** | LSD Motorsports | Groupbuys | 246 | 08-29-2013 01:35 PM |
