Old 02-01-2019, 12:30 PM   #1
dodj
Drives: Rallye Blue BRZ
Cold starting
With the recent chilly temps I am having some difficulty with starting the BRZ on cold mornings. By cold I mean -30* or colder. The car is plugged in, but it does not seem to either spark, or deliver fuel. There is no encouraging sounds of attempting to fire. Once the ambient temps 'warm up' to about -25* or so, it starts normally. We get a few days like this every year and this is the first year this has happened. So something has changed. Any ideas?
dodj is offline   Reply With Quote
Old 02-01-2019, 01:11 PM   #2
Is it stock?
Cranking at normal speed?
Old 02-01-2019, 01:57 PM   #3
Tokay444
Anti stance.
Tokay444's Avatar
Plugged in? Plugged into what?
Old 02-01-2019, 02:32 PM   #4
I assumed
http://www.ft86speedfactory.com/oem-...l#.XFSepHmWy70
Old 02-01-2019, 02:49 PM   #5
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
dumb question but is your fuel line frozen? ive heard fuel can start to freeze as high as -40f so if you have a bit of water in it you could be in trouble. i added 3oz of stabilizer and injector cleaner to my tank and started right up at -9f yesterday.
Breadman is offline   Reply With Quote
Old 02-01-2019, 03:07 PM   #6
Tokay444
Anti stance.
Tokay444's Avatar
Does nothing to keep the battery warm...
Old 02-01-2019, 03:10 PM   #7
wparsons
wparsons's Avatar
If it's cranking at normalish speed, then it's probably not the battery. I'd add some gas line antifreeze and see if it helps.
If it's cranking really slow, then it's like the battery either dying or freezing.
flickr
Old 02-01-2019, 03:16 PM   #8
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
I have a 2006 xB that I bought new. I hit a deer a couple of years ago with it on my way home from a gig. Cosmetically pretty bad but nothing functional was damaged (except a headlight, which I replaced with a little six LED light bar). It has well over 200k on it now and runs like new. If there is a hint that salt or snow may be hitting the roads, that becomes my commuter.
It's so embarrassing my wife refuses to ride in it, but it saves my FR-S from the bad stuff.
LotsaMiles is offline   Reply With Quote
Old 02-01-2019, 08:03 PM   #9
humfrz
Hey, LotsaMiles - did your brain slip a cog? -
humfrz
Old 02-01-2019, 08:06 PM   #10
humfrz
With the recent chilly temps I am having some difficulty with starting the BRZ on cold mornings. Any ideas?
You're up, there dodj -
humfrz
Old 02-03-2019, 09:27 PM   #11
dodj
humfrz
Yes, sorry, left town for the weekend.
The car is completely stock. It turns over at normal speed.
Plugged into a 120vac outlet......
Battery has lotsa juice to continue cranking.
So it is spark or fuel, but I'm not sure which. At -25* it is fine. So I'm thinking it is not fuel freezing? But why would cold temps interfere with spark? Electricity likes it the colder it gets.
Old 02-03-2019, 09:37 PM   #12
steve99
https://en.m.wikipedia.org/wiki/Flash_point
At -30 your getting close to the flashpoint of gasoline where its vapours wont ignight
Also the oil is very cold and thick and may restrict cranking rpm of motor
Old 02-03-2019, 10:04 PM   #13
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Electricity does like the cold but that's at liquid nitrogen temps and has more to do with conductivity and lowering resistance.
You have to be sure your battery is outputting enough CCAs. Also you might need more than just a block heater, maybe adding a oil pan heating pad would help. Also test the block heater as well to ensure it's actually properly heating the coolant.
If you weren't getting spark I'm pretty sure you'd throw a code. I'd check the fuel pressure at those temps.
Old 02-04-2019, 07:36 AM   #14
dodj
Hmmm. Didn't know that. However, don't think that is the root cause of my failure to start. (Most vehicles around here started in the same temps)
BREATHE IN THAT COLD AIR! AMAZING DEALS ON COLD AIR INTAKES AT EAST END RACESHOP! eastendraceshop Engine, Exhaust, Bolt-Ons 50 09-24-2019 06:45 PM
Subaru BRZ With e85 Flex Fuel Kit Not Starting In Cold morswestford Engine, Exhaust, Transmission 52 05-03-2017 06:50 PM
How cold is too cold to seal and wax? Jertronic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-01-2013 11:20 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Starting it off e10rice Mid-Atlantic 93 03-26-2012 03:16 PM
