Old 01-19-2019, 11:47 PM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Disable boomerang lights, is this possible
I had a headlight replaced after hitting a deer in 2017. The original headlight boomerang is more yellow looking than the new headlight which is bright white. Is it possible to disable these lights? Is there a plug I can disconnect?
Old 01-20-2019, 12:37 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I would make the case to whom ever fixed it, that the old one needs to be replaced because compared to the new one it's not right.
Old 01-20-2019, 03:32 AM   #3
Mr_Eyo
Drives: 2017 Toyota 86
Just cut the wire feeding it power. The wiring diagram is floating around here somewhere.
Mr_Eyo is offline   Reply With Quote
Old 01-20-2019, 04:24 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
DO NOT CUT ANYTHING ON YOUR CAR. If there's a solution without cutting do so, there are two methods software and unplug resistor option I prefer the software option because you use the obd2 port to simply forward a command:
Download something like carista and buy an elm327 obd2 dongle: pay for the modifications option and disable drls
OR
torrent techstream by a usb obd2 cable and disable it that way
Alternatively, find the DRL resistor which is behind the front bumper and unplug it, I'm unsure whether this is the same for the BR-Z with LEDs. There is also a 10amp drl fuse in the interior fuse box, and also a DRL relay or fuse in the engine fuse box.
Play around with em till you get the desired light effect without effecting high beams or other lighting
Honestly I only prefer the software solution because you can use the app on multiple cars for diagnosing things and because you don't touch anything hardware related
Old 01-20-2019, 04:35 PM   #5
B-R-Z
B-R-Z's Avatar
I know, and trust me I thought about that and it would be ideal but it may be a tough push being the headlight is 100% functional and was unscathed in the accident. Plus, my insurer is also my employer, I do not want to ruffle feathers where I eat. MY13 ones are very dim anyhow compared to the newer model years, which sucks to begin with. I'd rather just turn both off than have one mismatched.
Not completely against it but its not my preference. I could always re-solder the wire to undo it I guess.
OR
The boomerangs are not DRL's, they are technically parking lights, right? And I never cut anything, the most I've done is spliced into wires for any of my mods. It really sucks that LED's change color over time. I wonder how hard it would be to replace the boards, diode dynamics sells and RGB kit so it's definitely doable. I'd likely just put in some white replacements.
https://www.diodedynamics.com/2013-2...ed-boards.html
Edit: I think I am going to do the LED replacement. This will also allow me to swap out the factory HID lenses with the STI-R's to give that sharp beam pattern that I miss with the S2000.
Old 01-20-2019, 05:47 PM   #6
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
You can unplug it. Simple answer.
Dr. BRZ is offline   Reply With Quote
Old 01-20-2019, 11:54 PM   #7
FRSBRZGT86FAN
http://www.ft86club.com/forums/showthread.php?p=2445685
I've always considered them the DRL, they use the same circuit.....
Old 01-21-2019, 12:47 PM   #8
B-R-Z
B-R-Z's Avatar
Yeah, I found a few videos/posts that cover taking these apart and it seems like a relatively simple weekend project. I think I will go with the white/amber version that does blinker switchback instead of the RGB. https://www.diodedynamics.com/2013-2...ed-boards.html
I can kill 3 birds with 1 stone:
1. Boomerang LED replacement
2. STI-R HID lenses
3. Blackout
Old 01-21-2019, 01:32 PM   #9
Dr. BRZ
Dr. BRZ's Avatar
2. STI-R HID lenses
3. Blackout
A good portion of the brz headlights are blacked out already
Old 01-21-2019, 05:36 PM   #10
B-R-Z
B-R-Z's Avatar
Still a lot of chrome in there though, if I have them apart, may as well paint them.
Help! boomerang, sidemarkers, tail lights not working! thunderlights Cosmetic Modification (Interior/Exterior/Lighting) 5 01-08-2020 01:27 AM
Burnt out Boomerang JoeS Cosmetic Modification (Interior/Exterior/Lighting) 6 12-09-2018 02:08 PM
Boomerang sidemarker scubie.brz Cosmetic Modification (Interior/Exterior/Lighting) 10 10-12-2016 08:18 AM
Boomerang light is out JJJMan75 Issues | Warranty | Recalls / TSB 15 07-24-2015 12:01 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 02:09 AM
