Drives: 2016 brz
Time attack BRZ
I have a super low mileage brz that im considering to tear apart to compete in the Gridlife TA series in 2020. i contemplated swaps and i think id rather just send the FA to my engine builder and have a 500ish turbo build for the season.
the only issue is the trans. are people swapping these? adapter plates to mate up other trans? i have a cd009 from my turbo 350z days in my garage. those are bulletproof. i cant find anything on the internet. id appreciate any advice. the plan is to build for track mod. i dont have a desire to run in street. |
| The Following User Says Thank You to Mulletsnax For This Useful Post: | Strife26 (01-18-2019) |
Drives: 2015 Subaru BRZ Series.blue
Probably not the guy with the right answers but I know the trans is replaced often enough in these things and aren't great for the higher hp builds iirc.
If no one provides an answer I'd watch some of the YouTube vids with fully built twins. They'd probably give you an idea as to how they handle the trans situation (if there is one). Sent from my ONEPLUS A6013 using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
Drives: BRZ, Canyon
Glad to see another twin joining the Gridlife Time Attack field. I'm running in street class again this year.
As far as the trans goes, at that power level, I would at least upgrade the synchros. As far as i know, those are the biggest issue people have with the trans. I thought I read something about an adapter to use the cd009 but I don't have solid proof. edit: looks like its possible but likely requires modifications to the trans tunnel since the cd009 is bigger. https://www.pureautomotiveperformanc...-frs-brz-gt86/ https://www.mazworx.com/mazworx-favq...t-frs/brz.aspx |
#4 | |
Drives: 2016 brz
Ill do whatever mods i have to. Im not a good fabricator so i rely on off the shelf parts. You run into any issues with your twin? Any weakness i should address?
First step, sell the low mileage car and buy something with a blown engine or higher mileage. You're going to be rebuilding so much of it that it that you can probably make a couple thousand on the deal easily.
Second step, look into heat management for a turbo build like that, make sure it works with any aero you have planned. The CD009 kit doesn't require extensive modifications to the tunnel, remove old brackets and weld on new ones: https://www.mazworx.com/Docs/60150-F...dapter-Kit.pdf
BoostedBRZ
Drives: Turbo BRZ
looks like you'll be joining me. I have plans for street mod with GL in 2020. Turbo build too. You'll most likely be in street mod too. If you swap, you're automatically in trackmod and those dudes are in a whole different ball game. Street mod is already extremely competitive. Both Jackie Ding and Dewey moved up from Street class to compete in Street mod. So you'll most likely be battling them and whomever is already the holder in SM just as an FYI.
highly recommend getting Verus' radiator. I have it and it's amazing. +1 on heat management. I've gotten a turbo blanket, but have been meaning to wrap my hot parts on top of the coating it already has. Hood vents, if you don't already have them. Lastly, some form of ducting is always good for your oil cooler/intercooler setup you'll have. I can't comment on trans. My build is roughly at 325-350whp if I could guess. So far the trans has held up for 3 years at the track, 2 of it being supercharged, 1 of it being turbod. good luck with your build!
| The Following 2 Users Say Thank You to pgranberg11 For This Useful Post: | ATL BRZ (01-22-2019), Shark_Bait88 (01-22-2019) |
#7 | |
Senior Misanthrope
| Ontario Time Attack | Frost | CANADA | 12 | 08-21-2017 05:08 PM |
| The time attack build by Rob | SavingManuals | Member's Car Journals | 8 | 04-27-2014 08:01 PM |
| New Griffon Time Attack Vid | NemesisPrime909 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 23 | 02-12-2014 05:46 AM |
| AJ BRZ at Global Time Attack ! | AJ PwR | Tracking / Autocross / HPDE / Drifting | 5 | 11-26-2013 10:33 PM |
| My FR-S In Time Attack Mode!! | track_warrior | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 12 | 09-25-2012 02:13 AM |
