Old 01-09-2019, 01:01 AM   #1
1quickchic
Drives: 2013 Panda ft86/FRS
sti maf in 4" pipe
anyone have any experience with this? or even the stock maf in the 4" pipe?
1quickchic is offline   Reply With Quote
Old 01-09-2019, 06:12 AM   #2
steve99
Some info here
But your going to have to scale it from scratch
https://www.ft86club.com/forums/showthread.php?t=106496
The Following 2 Users Say Thank You to steve99 For This Useful Post:
1quickchic (01-09-2019), Yobiwan (01-11-2019)
Old 01-09-2019, 11:08 AM   #3
1quickchic
Thanks,I used that as a start on blow through, but on a 2.75 pipe it was hitting max voltage and could get it consistently reading. so I moved it to the front of the turbo which is in a 4" pipe and now, it straight wont start. its a sti maf, I haven't tried the stock maf yet as I don't got it anymore o_o
Old 01-09-2019, 08:01 PM   #4
steve99
Check map sensor as well and you have correct map sensor scalaing in tune as well as maf sensor.
Unplug maf sensorconpletly and see if it starts in failsafe mode
If you have a maf extension harness check continuity
Old 01-10-2019, 01:25 AM   #5
1quickchic
map has been rescaled to omni 3 bar settings, no extension harness, tried unplugging maf but think its to out of tune do to the port work. putting the maf back into the 2.75 pipe from the 4" as it did run, just not perfect, thoughts on using a resistor on the maf to ower overall reading? maybe got a bad maf as this was a used maf off ebay ...
Old 01-10-2019, 08:18 AM   #6
steve99
Resistor wont work
The maf is just a sensor that put out 0 to 5 v depending on the velocity of the air flowing past it. Iits a hot wire sensor compenssted for temperature. The ecu will only accept 0 to 5 v then interprets that as air flow. Bigger tube lower velocity for same air volume.
4" tube is is over double the cross section of the 2.75 so you likey going to need to double the values in the !af maf flow numbers in maf scale​ as a rough start poimt
Resistor will just screw up readings. Wont help your problem.
Old 01-11-2019, 03:17 AM   #7
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
I think if maf is located before turbo, BOV will screw reading.
MAF should be between BOV and Throttle body .
how about try new 3" pipe instead of 2.75 pipe . That will give slightly more room .
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 12-10-2019, 02:35 AM   #8
tomm.brz
Drives: brz 2017 hksv2
What about....ecutek and none of this is a problem since you setup a hybrid SD with full SD after a certain load and you keep the maf in blow through configuration that measures charge temp instead of the useless intake temp pre turbo
OK sorry, joking... I leave
JDL 3" Over-Pipe/Front-Pipe Combo-Pipe SOLD Jbelmonte Engine, Exhaust, Bolt-Ons 3 03-08-2018 10:00 PM
FS: Nameless 2.5" Resonated Downpipe (Over Pipe + Front Pipe) username404 Engine, Exhaust, Bolt-Ons 1 05-04-2016 12:51 AM
FS: "Brand NEW" 2.5" INVIDIA Catless Resonated Front Pipe FRSH86 Engine, Exhaust, Bolt-Ons 13 08-10-2015 01:10 PM
WTB Catted 3" Perrin front pipe/down pipe DrDavid Want-To-Buy Requests 0 07-19-2014 07:54 PM
