Old 01-02-2019, 10:14 AM   #1
alphasaur
friendly
Drives: 17' 86
JVC KW 740bt maestro and 2017 toyota 86 issues
Hello,
I recently ordered the JVC KW740bt, maestro, and Maestro TO1 harness from crutchfield. I paid the extra few dollars to have crutchfield wire up the harness.
Install:
Audio appears to work great (far better sound than stock, or perhaps placebo)
Mic works
Android auto/usb works
Issues:
When the canbus is hooked up gauges work however there is an issue where when I press the brake pedal, camera is triggered on the head unit? Going into reverse does not appear to trigger camera on head unit.
I have not successfully wired up the camera and am waiting for a pac harness to arrive as I tried splicing the cables from the 24 pin plug unsuccessfully.
According to maestro site the Maestro Harness should be the SUB01 harness??
Anyone have any insight?
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 01-02-2019, 04:57 PM   #2
ScionWolf
Drives: '13 Scion FR-S
Sounds like the reverse trigger was wired up wrong. The wire colors vary depending on the head unit. As far as the sub01 harness, maestro was supposed to be getting away from the to1 harness due to a battery drain issue.
Can't give more info than that right now as I'm at work, but just some very basic surface level info.
ScionWolf is offline   Reply With Quote
Old 01-02-2019, 07:02 PM   #3
alphasaur
friendly
Drives: 17' 86
Ah, thank you sir much appreciated! Will appreciate more info when you're able.
Old 01-08-2019, 03:56 PM   #4
alphasaur
friendly
Drives: 17' 86
finally got everything working, would anyone want a write up of this?
Old 01-09-2019, 03:54 PM   #5
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Post up!.. I’ve read a few post from people inquiring about this interface.
el-guapin is offline   Reply With Quote
2017+ BRZ and Maestro RR COBlue Electronics | Audio | NAV | Infotainment 62 04-15-2021 12:00 PM
Installing Pioneer HU and Maestro RR NCtoBRZ Electronics | Audio | NAV | Infotainment 56 05-20-2019 08:16 AM
Pioneer W8400 with Maestro RR? STI-ish Electronics | Audio | NAV | Infotainment 13 02-11-2019 12:07 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
Fuel Pump and clutch issues on 2017 fixed? sfdai0 Issues | Warranty | Recalls / TSB 8 05-05-2017 08:24 PM
