Old 12-30-2018, 11:55 AM   #1
PuslarBrrrz
Hot Version 145 86's VS many with Subtitles
Courtesy of TofuJoe
PuslarBrrrz is offline   Reply With Quote
Old 12-30-2018, 04:36 PM   #2
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Nice!.. THNX for sharing!
el-guapin is offline   Reply With Quote
Old 01-01-2019, 03:11 PM   #3
Lantanafrs2
Drives: 2013 frs red
Thanx for that link! So now we know that toda 2.3l is good for 15hp and sequentials with proper ratios are the tits.
Old 01-01-2019, 10:54 PM   #4
PuslarBrrrz
Interestingly enough Revolution Garage was able to get about 214whp(246bhp) from their 2.1/2.2L they finished recently. But their dyno still shows the familiar 6500 fall off. I'm all for a meatier midrange but even flat lining after peak hp like those pesky Hondas would be nice.
Old 01-02-2019, 03:54 AM   #5
Lantanafrs2
Cam profiles
Old 01-02-2019, 05:14 AM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It was never about peak power with the Toda 2.3L kit. There were lengthy discussions here in the past and people didn't get it at that time. As mentioned in the video it is about a much better mid rev range torque which helps on corner exiting. Not a coincidence that the specific car had the highest 86/BRZ top speed and even better than the Honda Civic Type R and the NSX Type R!
Old 01-02-2019, 12:07 PM   #7
PuslarBrrrz
Cam profiles
Could just as easily be the factory IM which we know is a bottle neck.
Forgot I had this dyno of Revolutions old 2.3L from years ago. I assume they used the Toda 2.3L kit. It had VVT issues in the upper rev just like their 2.1 initially according to their diary before they cleaned it up.
Old 01-02-2019, 12:23 PM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It is not only about the intake manifold. In general a percentage increase in engine displacement doesn't mean always a similar percentage increase in power! Check for example the power output of the FB20 and the FB25 engine. The FB20 outputs 148hp and the FB25 outputs 170hp.
Old 01-02-2019, 01:03 PM   #9
PuslarBrrrz
I wasn't referring to percentage output but rather power delivery and torque curve. I would expect diminishing returners too if the only thing changed is the displacement as the original design is optimized for a smaller capacity.
Old 01-02-2019, 01:18 PM   #10
Lantanafrs2
If the intake is a bottleneck why can't anyone improve on it?
Old 01-02-2019, 02:40 PM   #11
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Courtesy of TofuJoe
Hot Version and Best Motoring are great programs. They genuinely thrash the cars, and it's great to see how they react. Scantily clad kawaii girls are a bonus.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 01-02-2019, 08:27 PM   #12
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Cam profiles
Toda has released recently a high power profile camshaft. It was not used in the car mentioned in the video. Probably, it helps in the higher rpm area.
Old 01-02-2019, 08:46 PM   #13
Lantanafrs2
I would imagine that bigger valves and port work would benefit the larger displacement. No end to it. Lots of money needed
Old 01-02-2019, 08:50 PM   #14
Lantanafrs2
At a certain point, longer duration and more lift cause driveability issues as compression bleeds off at lower rpm due to increased overlap.
Hot Version 145 with subtitles TofuJoe BRZ Photos, Videos, Wallpapers, Gallery Forum 2 12-30-2018 02:19 PM
(UPDATE w/ Lengend 3) Initial D - Legend 1 & 2 (with Subtitles) finch1750 Off-Topic Lounge [WARNING: NO POLITICS] 29 08-01-2016 05:04 PM
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 12:23 AM
Which version in UAE? sh4d0w ASIA 44 09-18-2013 07:44 AM
Do you think we are going to see a trd version or 5axis version of the FRS next week DIG1992 Scion FR-S / Toyota 86 GT86 General Forum 9 01-04-2012 06:59 AM
