Old 12-25-2018, 08:51 AM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
OBDII 52mm oil temp gauge
Hello Guys,
I'm looking to add an integrated oil temp gauge to my 86. I've seen the P3 vent gauge which is a really elegant solution, but at almost $500 over here in Europe, it's a little steep.
There are cheap adapters for 52mm gauges using the driver's side vent (appx. $20), which require a 52mm OBDII gauge capable of displaying oil temp. Is there a go-to gauge for 86 users that does this?
Best regards,
Alex
alex87f is offline   Reply With Quote
Old 12-25-2018, 09:53 PM   #2
jflogerzi
jflogerzi's Avatar
Originally Posted by alex87f View Post
Hello Guys,
Best regards,
Alex
Why not use a cheap/old mobile phone that works with torque or the iOS equivalent? get a phone mount that can use on your dash or vent style. Also you use OFT tunes, the OFT device can read oil temps and even display it as an gauge
2013 Series 10 FRS #553
Old 12-26-2018, 06:03 AM   #3
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Pivot makes a guage specifically for the twins that shows both water temp and oil or intake temp. There are two models, one with a white backlight for the 86 and one with a red backlight for the BRZ.
https://pivotjp.com/product/dual-gauge/index-e.html
https://global.rakuten.com/en/store/cps-mm/item/n22853/
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
norcalpb (12-26-2018)
FS: CravenSpeed Dual Guage Pod + ATI 52mm Vent Gauge Pod skylinekin Interior Parts (Incl. Lighting) 1 05-22-2017 06:43 PM
FS: 52mm Steering Column Gauge Pod skylinekin Interior Parts (Incl. Lighting) 2 02-11-2017 09:35 AM
Block8head defroster vent gauge pods (all 52mm varieties) with pictures. Cheeseballs Cosmetic Modification (Interior/Exterior/Lighting) 25 03-20-2016 10:46 AM
52mm AT temp gauge rAzEn Tracking / Autocross / HPDE / Drifting 2 01-03-2016 10:03 PM
Custom gauge pod (52mm) Fizz Australia Classifieds 2 12-01-2015 07:58 AM
