Drives: turbo frs
how to tune 2step ecuTek
Dear
I have turbo frs tuned buy ecuTek How can I tune 2step ?? Thank Also can I tune NA frs OFT maps to work with 2step ?? I use for NA cars tactrix cable and romrider and ecuflash Thnx alot |
#2 | |
With ecutek 2 step is called launch control You need to go to racerom features and enable it , it will then work with the default parameters If necessary you can finectune a few parameters if needed See ecutek manual below page 9 https://ecutek.zendesk.com/hc/en-gb/...eatures-Manual With oft maps the launch control is a very simple setup it jist ajist an extra rev limiter active whan vehicle stationery.. You jist set one parameter launch rpm delts which is redline rpm - delta = lainch rpm |
#3 | |
Drives: turbo frs
Thnx Steve Can u show me how I can do that with oft ROMs?? Snapshot .. |
Drives: turbo frs
Also can at 2step be some flams or backfire ??
Very difficult to get any flames and pops with brz\86 as this ecu uses fuel cut to limit rpm not ignition cut,
With oft you jist need oft roms and oft romraider defs amd you alter the launch control parameter only one parameter in oft roms |
#6 | |
Drives: turbo frs
Could you please show me please at romraider how to do this? |
| Ecutek Tune? | Jadrien86 | Software Tuning | 7 | 10-29-2016 05:41 PM |
| Ecutek Tune | tyler_win_photo | Software Tuning | 2 | 10-26-2016 06:37 AM |
| ECUTek E85 TUNE !! | c1m8y11 | Engine, Exhaust, Transmission | 2 | 07-10-2014 04:06 PM |
| EcuTek Tune | SalM | Software Tuning | 20 | 01-30-2014 11:09 PM |
