Old 11-26-2018, 06:09 PM   #1
Dadillac
Drives: 2018 Ford Mustang EB Premium 6M
TRD springs
Am deciding if I want to lower my brand new car or not. I like not scraping anything so if I do lower it I will use the TRD springs as it only lowers a bit more than half an inch. Have a question for TS owners or anyone with the sachs dampers who may have used the TRD springs. How is the ride quality? I really do not want to stiffen up an already stiff ride. Really would be nice to lessen "the gap" but only if there is no negatives involved. Thanks
Don
Modern warriors saddle iron horses of chrome
Dadillac is offline   Reply With Quote
Old 11-26-2018, 06:22 PM   #2
monkeybike
Drives: 86
They lower 1", not 0.5"
Another thing to think about is spring rates. The RS*R Superdowns for BRZ lower the car about 1.2" but they are softer than the TRD or RS*R 86 versions in the rear.
RS*R Superdown BRZ
Front 3.16kg/mm
Rear 3.88kg/mm
RS*R Superdown 86
Front: 3.16kg/mm
Rear: 4.49kg/mm
TRD (allegedly Eibach Pro-Kit)
Front: 3.6kg/mm
Rear: 4.9kg/mm
monkeybike is offline   Reply With Quote
Old 11-26-2018, 06:25 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I only scraped 2 or 3 times in 70K miles lowered 1". I had Eibach Prokit springs.
IMO, there is no downside to installing them. I have coils now; many downsides mixed with some up too...
I LIKE TIRES!
Old 11-26-2018, 06:36 PM   #4
Dadillac
I stand corrected they do lower an inch. I thought I saw 15mm some where. But do either of the above suggestions take into account Sachs dampers vs stock dampers? Or would that really not matter too much?
Don
Old 11-26-2018, 06:38 PM   #5
Dadillac
Where could I find the info on the spring rates that I have in my 2019 86 TRD SE? Dampers and springs are what the BRZ TS would have. Would love to know if the lowering springs are softer, firmer, or equal to what I have. Thanks
Don
Old 11-26-2018, 06:40 PM   #6
RS*R Superdown BRZ
Front 3.16kg/mm
Rear 3.88kg/mm
RS*R Superdown 86
Front: 3.16kg/mm
Rear: 4.49kg/mm
Front: 3.6kg/mm
Rear: 4.9kg/mm
On paper the RSRs are 1.2 in the front and 1.4 in the rear. In reality mine are closer to 1.5 in the front and 1.7 in the rear.
The ride is fine except when I hit a bump fast enough to hit the stops. Think they would be fine with the Sachs.
The TRD are made by Eibach but that does not mean they are the same. I think they would be fine as well though.
Old 11-26-2018, 06:43 PM   #7
monkeybike
Drives: 86
Don
JDM STi lower 15mm. Sachs PP are a pretty rough ride IMHO.
Most people will tell you to get RCE Yellow springs which are about 4.5kg/mm front and rear.
RS*R have the softest spring rates.
Old 11-26-2018, 07:30 PM   #8
Decep
Drives: 2013 FR-S Series 10
You will stiffen up the ride, there's no free lunch here. Less suspension travel = more jarring impact on the big bumps. Small imperfections will be fine, if anything the small stuff will be softer, since the shocks are now a bit underdamped versus stock.
Honestly depends on the roads where you are.
I would look at the RCE yellow springs, they lower a little under an inch. Get camber bolts for the front while you're in there, and max out your camber.
Old 11-27-2018, 12:39 AM   #9
gpvecchi
gpvecchi's Avatar
Don
BRZ ts dampers are not the same Sachs of the PP/TRD USA
gpvecchi is offline   Reply With Quote
Review: Swift Sport Springs vs RCE Yellow springs on B6 Shocks EGOBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-15-2018 08:21 PM
Widest wheels without rubbing on stock springs with eibach springs ? H214M Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-09-2017 11:41 AM
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs leunglambs NY / NJ / CT / PA 3 06-09-2017 02:49 PM
WTB: RCE yellow springs or eibach prokit lower springs fr/brz Gt86-turbo Want-To-Buy Requests 0 03-08-2015 03:18 PM
Swift Sport springs/or any springs.. regrets ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-21-2014 09:10 PM
