Drives: Galaxy Blue BRZ
Torquing strut nut
I did not want to resurrect any of the strut/spring threads but I have a question. In theory, to torque the center strut nut to 41 ft/lb a crows foot must be used. This could add length which in turn would change the calculation. Could I use the torque wrench on the Allen socket and tighten the nut until the the value is obtained?
Thanks
I just give a quick zip with an impact.
If you don't have one use a crow foot or pass through socket and make it "tight". If you are worried add some blue loctite. I wouldn't worry about getting the torque exactly right.
Drives: Legacy GT
Since torque is force x distance, you can just correct your torque wrench setting for the added length with a little math.
Or just turn it down like one click. it doesn't have to be that exact. Or use a standard socket and a strap wrench around the shock shaft. I would not try tightening the shock shaft via th allen key. I think you could break the top of the shock shaft that way plus it would require more force to reach the same "tightness." |
Drives: 2017 86 6-Speed
If you put the crow's foot on the torque wrench so that is it perpendicular to the wrench handle, the difference in torque will be negligible.
2017 86 set up for CS STX autocross
| Strut Bar Review: AEM Strut Bar Thoughts and Experiences | wu_dot_com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 03-08-2019 04:33 PM |
| <FS> Perrin 25mm rear sway, Radium front strut, Cusco rear strut bar | mav1178 | Brakes, Suspension, Chassis | 2 | 07-21-2016 05:49 PM |
| Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More | SOURCE,LLC | Brakes, Suspension, Chassis | 445 | 05-11-2015 05:41 PM |
| "Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE | Jason@DSG | Groupbuys | 14 | 12-31-2013 09:06 AM |
