Old 11-22-2018, 11:24 PM   #1
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Jrsc squeak and squeal that is hard to Locate . Any info would be appreciated !!
I have a squeak or squeal and not sure where it is coming from . I have the jrsc as fi and was wondering if anyone else has had the same issue . After driving the car for a bit the squeal reduces but on cold starts or starts after it's sitting for a few hours it will do again . I have added belt dressing and also have tried adding oil as lube on the older pulley where there is like a rubber type seal . Here is how it sounds and my apologies on the angle . Is there a way to add video ?
mswbrz is offline   Reply With Quote
Old 12-03-2018, 12:45 PM   #2
NV89
NV89's Avatar
Drives: 14 BRZ, Genesis coupe track, 05 sti
My hks does the same thing
Sent from my Pixel 3 using Tapatalk
NV89 is offline   Reply With Quote
Old 12-03-2018, 03:33 PM   #3
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
If you add oil on a pulley, its gonna fling it. It will get on the belt. The belt will make noise. Make sure the belt is clean, and idler pulleys are ok.
JDMChris is online now   Reply With Quote
Old 12-03-2018, 09:54 PM   #4
mswbrz
mswbrz's Avatar
I had a slight oil leak from the oil cooler filter mount that happened to get on the belt . After several attempts of cleaning the belt I was able to isolate the sound by adding a bit of water to the belt as the car was running . When I would spray the belt it would stop squeaking and omitted the chance of the pulleys squeaking . I bought a new serpentine belt as the one on the jrsc was pushing 3 years old and it was slightly glazed looking , after the belt change the squeak is gone and had not returned . Lame we can't post vids on here unless via you tube link . Thought I would follow up with y'all
Old 12-03-2018, 10:23 PM   #5
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
Nice. My belt does the same thing. It’s super annoying
Bones36 is offline   Reply With Quote
Old 12-03-2018, 11:09 PM   #6
mswbrz
mswbrz's Avatar
Yeah drove me nuts man I couldn't handle it
Old 12-04-2018, 12:29 AM   #7
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
mine goes away after about 10 minutes. where's the best place to get a new one?
The Following User Says Thank You to Bones36 For This Useful Post:
mswbrz (12-04-2018)
Old 12-04-2018, 03:07 AM   #8
mswbrz
mswbrz's Avatar
You can get one directly through Jackson racing or just have oriellys order you one . Are you a fan of team sesh ?
Low speed squeal / squeak noise highway7 Issues | Warranty | Recalls / TSB 16 08-02-2021 05:42 AM
Difficult to search for and locate specific text in forum. Darth Khan Off-Topic Lounge [WARNING: NO POLITICS] 7 09-27-2017 07:37 AM
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
My 14' FRS Appreciated In Value!!! Phantobe Scion FR-S / Toyota 86 GT86 General Forum 21 01-18-2017 07:13 AM
Trying to locate GReddy or 6666 to buy the Rocket Bunny kit direct FT-86GOD Cosmetic Modification (Interior/Exterior/Lighting) 5 11-13-2012 02:38 AM
