Old 11-20-2018, 01:44 PM   #1
Scott'18Brz
Drives: 2018 Limited BRZ
To boost or not to boost...
I picked up a 2018 BRZ with the performance package a few months ago.
I am wanting more power, but to stay safe on the car since it is so new.
I want to boost, but I hear a lot of negative opinions from people on this page.
Ideally; I would like to get her up to 250-275whp to make her more fun to drive as my daily.
What are your opinions?
What setup would you recommend?
Scott'18Brz is offline   Reply With Quote
Old 11-20-2018, 01:45 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
making sure I'm getting a good seat for this one
HKz is offline   Reply With Quote
The Following 3 Users Say Thank You to HKz For This Useful Post:
kch (11-26-2018), MCTeeJ (11-20-2018), mistople (11-21-2018)
Old 11-20-2018, 01:51 PM   #3
alphasaur
friendly
Drives: 17' 86
How did you arrive at 250-275whp?
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
kch (11-26-2018)
Old 11-20-2018, 02:09 PM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Edlebrock Supercharger + Delicious Tune + JR Dual Radiator Oil Cooler = Done.
MS, CSCS, TSAC-F, CPT
The Following 3 Users Say Thank You to weederr33 For This Useful Post:
DarkPira7e (11-20-2018), gtengr (11-20-2018), Summerwolf (11-21-2018)
Old 11-20-2018, 02:13 PM   #5
Scott'18Brz
Talking to various shops and people. Most have told me to stay under 300whp and avoid problems and/or beefing up internals... Im still trying to learn about the car.
Old 11-20-2018, 02:15 PM   #6
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
I live in Florida, and many 86's are boosted here simply because everything is flat and straight. The only thing they can do on the street is go fast in a straight line because that's the only thing FL offers (outside of tracking, autoX, etc.).
If you have fun mountain roads where you live or at least something remotely interesting the car has enough power NA.
That said, do whatever you want.
MCTeeJ is offline   Reply With Quote
The Following 2 Users Say Thank You to MCTeeJ For This Useful Post:
HachiRokuX (11-21-2018), Leonardo (11-20-2018)
Old 11-20-2018, 02:44 PM   #7
sid94
Drives: 2013 frs
Boost it stay around 250 on E85 along with an oil cooler and you’ll be fine
You’ll also end up possibly getting greedy turning up the boost and boom then the real fun starts
sid94 is offline   Reply With Quote
Old 11-20-2018, 02:54 PM   #8
bfrank1972
Drives: 2013 FR-S Argento
Just one perspective - people initially always worry about catastrophic failure. Add a turbo or supercharger and kaboom. In reality, while that is a risk, much more common headaches occur. Boost leaks, bad tunes, snapped pulleys, failed supercharger units, failed BOV's etc. etc. "Small" headaches. If you're not prepared to deal with that, then don't add boost of any kind. Or if you do, make sure a very competent installer and tuner do the work on your car to minimize potential headaches.
bfrank1972 is offline   Reply With Quote
The Following 9 Users Say Thank You to bfrank1972 For This Useful Post:
Apoc (11-22-2018), gtengr (11-20-2018), HachiRokuX (11-20-2018), kch (11-26-2018), sly (11-21-2018), Spuds (11-20-2018), Summerwolf (11-21-2018), Tcoat (11-21-2018), weederr33 (11-20-2018)
Old 11-20-2018, 10:29 PM   #9
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
There is E85 in Eugene which is like 45 minutes away from Corvallis, so that isn’t an option unless I’m mistaken. Being that is the case, a basic kit like JRSC or Edelbrock, and if smog isn’t an issue, or a decent small turbo kit would all work. If you did E85 then you would need injectors and a pump too.
Old 11-21-2018, 12:24 AM   #10
jakebrz
Drives: Charcoal Gray BRZ 6MT
i would never suggest boosting stock engine. i boosted my brz and ran fuel flex + e85 on 9psi and i blew it in a week at 5K rpm. i was probably above 300whp but either way there is no reliability.
on the other side of things, now that im 20K into a full build i drive all day long with a smile.
so....
risk/reward
jakebrz is offline   Reply With Quote
The Following User Says Thank You to jakebrz For This Useful Post:
Old 11-21-2018, 10:02 AM   #11
gtengr
Drives: 2017 BRZ
To boost. Just don't get to greedy with it. I prefer the TVS-based kits due to the OEM applications of the blower.
gtengr is offline   Reply With Quote
Old 11-21-2018, 10:30 AM   #12
mrg666
pessimistic skeptic
mrg666's Avatar
I have been driving with JRSC (CARB tune) close to two years, ~20K miles, all year snow, rain, or shine. It is very reliable, efficient, and fun. I installed it and I do the maintenance and fixing of my car. There is additional maintenance and quirks to take care but it is worth it. I chose JRSC since it had the best track record when I was deciding, very simple kit, least intrusive FI modification, no drilling/cutting, minimal rerouting. It just clicks in the engine bay. Low rpm torque is low that helps with engine reliability and high rpm power is up there with all other options at stock level; linear and smooth power delivery. Plus, my MPG with normal driving is the same if not improved vs stock engine. So I can recommend it. This engine is designed to rev up. If you respect its capabilities and design, it will deliver. Keep the torque/boost low especially at low rpm, improve cooling, make sure the tune is conservative. Tune is *very* important and the tune for the most power is not the best one.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
HachiRokuX (11-21-2018), Tcoat (11-21-2018)
Old 11-21-2018, 11:44 AM   #13
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
The only real way to get "decent" horsepower out of these vehicles is to boost. If you want to take that chance on a new car, understand the potential risks and the benefits associated with your chosen method of boost.
Old 11-21-2018, 01:38 PM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I don't think this has been mentioned, but also be aware that with any FI modification you throw your warranty out the window. A big consideration.
That being said, I love my JRSC boosted FR-S. Another reason I went with JR is that it looks like it belongs, like the car could have came from the factory with it. My advice would be to have professionals with experience with the kit install it, and do not run an off the shelf tune, find an actual master tuner and get a safe tune.
I did have my C30 unit fail (bearing failure) about a year in, and was replaced by JR/Rotrex under warranty. The car was down for about 5 weeks waiting for the new unit. That was 13 months ago.
All About That Boost Sideways&Smiling Off-Topic Lounge [WARNING: NO POLITICS] 3 08-13-2015 02:10 AM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
