Old 11-09-2018, 09:54 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
235/40/17 on 17x9 +35 Enkei RPF1?
will this stretching the tires a bit? I’ve used 245/50/17 before on the same size wheels but did not like the fact the front tires are sticking out a bit.
stlgrym3 is offline   Reply With Quote
Old 11-13-2018, 06:26 PM   #2
stlgrym3
Anyone?
Old 11-13-2018, 06:27 PM   #3
FirstWinter
Drives: Car
It's fine
FirstWinter is offline   Reply With Quote
Old 11-13-2018, 06:36 PM   #4
arkanist
Drives: 2016 BRZ Limited, Stock
235 on a 9" is fine.
http://www.ft86club.com/forums/showp...&postcount=399
arkanist is offline   Reply With Quote
The Following User Says Thank You to arkanist For This Useful Post:
stlgrym3 (11-13-2018)
Old 11-13-2018, 06:54 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
235/40 is hardly a stretch. The Stock tires look stretched on a 17x9. What 235/40 are you getting? They are fairly rare. You could also get a 245/40/17. They are stock diameter.
I LIKE TIRES!
Old 11-13-2018, 07:05 PM   #6
tyler_win_photo
tyler_win_photo's Avatar
245/50 17 is way too tall of a sidewall profile
tyler_win_photo is offline   Reply With Quote
The Following 2 Users Say Thank You to tyler_win_photo For This Useful Post:
finch1750 (11-15-2018), Leonardo (11-13-2018)
Old 11-13-2018, 07:06 PM   #7
tyler_win_photo
You can bring in the poke in the front with some camber bolts or anything that allows adjustable front camber.
Old 11-14-2018, 12:38 PM   #8
stlgrym3
decided to go with 245 instead. anyone know if 245/40/17 on 17x9 +35 wheels lowered on RCE Yellow springs have any rubbing issue?
The Following User Says Thank You to stlgrym3 For This Useful Post:
Leonardo (11-14-2018)
Old 11-14-2018, 12:44 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
No rubbing issues. But a set of camber bolts in the front is suggested.
I LIKE TIRES!
stlgrym3 (11-14-2018)
Old 11-14-2018, 02:48 PM   #10
kch
Senior Misanthrope
kch's Avatar
It might be close to the front fenders. Adding a little camber will solve the problem.
The Following User Says Thank You to kch For This Useful Post:
Old 11-14-2018, 06:15 PM   #11
arkanist
https://www.ft86motorsports.com/wheelitfit/
According to that you are gonna need around 2 degrees of negative camber up front so that you don't rub the fender.
Old 11-15-2018, 07:49 AM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
That's wrong, sorry. Ive run 18x9 with 245/35 in the front with +37, +32, and +30 offsets. I had between -1 to -1.5 from just a set of camber bolts. Never rubbed the fender. though , I was close to the spring perch, but did not rub.
Op you will be fine.
Edit: I was also lowered more with softer springs in the front. Vs RCE Yellow springs.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
arkanist (11-15-2018), stlgrym3 (11-15-2018)
Old 11-15-2018, 12:34 PM   #13
arkanist
You are totally right, it looks like I might have entered something wrong - that's on me, don't blame the site I linked.
I am seeing OPs setup clearing with very little camber, and to verify the site I entered the fitments you mentioned and it shows them all clearing to a similar tolerance.
Leonardo (11-15-2018)
Enkei Rpf1 17x9 & Enkei Fujin 18x8 JoeCFRS Wheels and Tires 12 01-06-2018 09:39 PM
ENKEI RPF1 in 17x9 +35 & Team Dynamics PR 1.2 17x9 +35. PM for FORUM PRICE! OAKOS Automotive Groupbuys 145 12-14-2016 02:54 PM
PA:WTB/FT black enkei raijin 18x8.5 18x9.5 for enkei rpf1 17x9 SterlingBrz Wheels and Tires 1 05-28-2014 11:36 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
