Old 10-25-2018, 02:55 AM   #1
halujeddo
Drives: Subaru BRZ
2017 Ignition maps (K00G)
Hi all,
In earlier models (12-16) it was ok to tweak only "BASE TIMING B" table to adjust ignition timings. Is it same in new ones?
I see that "BASE TIMING A" looks also tweaked on 2017 BRZ V4 tune (K00G rom)
I need to pull some timing because of bad gas. I see -5 FLKC.
Shoud I adjust BASE TIMING B only or should I alter both A and B tables on K00G rom (2017)
halujeddo is offline   Reply With Quote
Old 10-25-2018, 04:39 AM   #2
steve99
Same in K00G as older roms.
Take timing from base B
Base A is a very conservative map ised as iam aproaches zero
Leave knock correction max A
Autocross with models 2017+ IAM (ignition advance at 0.7) nico_rsx Tracking / Autocross / HPDE / Drifting 22 08-24-2018 10:36 AM
OFT: Off-The-Shelf v2.072 maps now available Shiv@Openflash Software Tuning 22 02-13-2017 05:21 PM
OFT 91 vs 93 maps JoeCFRS Software Tuning 13 03-30-2016 04:21 AM
OFT maps for FI Triumphrider Software Tuning 25 10-16-2014 10:46 AM
