Old 10-19-2018, 10:22 PM   #1
psimitar
Drives: FA20 converted 1957 VW Bus
Fuel supply system query
Hiya y'all,
I've just joined this forum as I'm trying to find out how the stock fuel system on the 86/BRZ works.
Now don't shoot me for this next bit as I'm doing the mechanics for a mates project.
So an FA20 is being installed into a 1957 VW Bus. It's had a custom ali tank made and I'm trying to figure out thfuel system.
From what I've managed to glean from research the OEM system appears to use a fuel pressure regulator built into the in-tank pump/baffle unit. Is this correct?
I can see that the OEM only uses a single outlet from the in tank unit with no return so sounds like the regulator is in the in tank unit but then to run the multipoint and direct injection rails the supply line must have a Y connector in it somewhere? Correct?
But then what is the little solenoid bolted to the underside of the inlet manifold on the side where the mechanical fuel pump is? IS it some kind of vacuum line solenoid or part of the vapour purge system?
Thanks In advance,
Mike
psimitar is offline   Reply With Quote
Old 10-20-2018, 12:18 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by psimitar View Post
Hiya y'all,
Thanks In advance,
Mike
Yes, the fuel pressure regulator is in the in tank pump canister.
There's a Y close by the fuel tank that separates into two lines, one for direct injectors and one for port.
The solenoid below the intake is the EVAP solenoid. You're basically correct on your assumptions.
Old 10-20-2018, 01:09 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Link to the manuals is in my sig line.
Sportsguy83 (10-20-2018)
Old 10-20-2018, 04:18 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Hope you know the engine is both old school port injection AND direct injection.
Old 10-20-2018, 07:58 PM   #5
psimitar
Awesome. Thank you
Old 10-20-2018, 08:13 PM   #6
psimitar
Much thanks for clarifying my thoughts.
Good to know the evap solenoid can now be deleted from this particular vehicle
The Following User Says Thank You to psimitar For This Useful Post:
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
fuel system. Reaper Tracking / Autocross / HPDE / Drifting 2 08-06-2015 10:12 AM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
