Financial Distress
Drives: 2017 GT86 325WHP
Run slightly larger wall in rear?
Hey guys, so I'm currently running Enkei RPF1's 18x9.5 with 255/35/18 tires. My Coilovers are Yonaka Spec 2's (Camber adjustment), and I don't run slammed at all. I noticed recently how much room I have in my rear even with the 18" rim and was thinking of running a 265/40/18 on the back, would anyone be able to chime in and give some advice on running a 40 wall in the back with a 35 in the front? Major issues or just minor difference in the feel of the drive? The ride is raked towards the front the purpose of having room in the back.
Thank you in advance. |
Drives: '23 BRZ
Seems like a bad idea. You know 265/35-18 have more sidewall than 255/35-18, right? 255/35 front with 265/35 rear or 275/35-18 rears (a bit more sidewall still) would be a much better plan, I wouldn't even consider 265/40-18 which are more than an inch bigger in diameter vs 255/35
#3 | |
Country Boy 4 Life
Don't do it. A 265/40/18 is too big of tire. As ZDan has already said, stick to 35 series, if you want to go taller and wider. This thread has good info on page one about running 265 width. http://www.ft86club.com/forums/showthread.php?t=41083
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | scottryan (10-18-2018) |
A.K.A. Starlord
Drives: 2015 Series.Blue
That's a pretty large discrepancy front-to-rear. You're talking about a 20% taller sidewall, and a more than 5% increase in circumference, all for only a 4% increase in width.
Let's weigh the pros and cons. Pros: - *Slightly* more lateral grip (at the rear only.) - Improved looks if you like a bit of rake. - Improved ride comfort (at the rear only.) Cons: - Sloppier rear handling. - Slightly increased propensity for understeer. - Slightly less controllable rear end at the limit. - Incorrect speedometer/odometer readings. - Potential for ABS/TCS/ESC issues due to wheel speed sensor discrepancies. - Slower acceleration. - Slower top speed (at stock power levels, since our vehicles are drag limited.) - Greater unsprung rear mass (I assume the 265 will be heavier.) - More expensive tire (I assume it's more expensive.) - Inability to rotate tires front-to-rear to maintain even wear. - Inability to use spare tire for any length of time if you get a rear flat, seeing as the front tires (which are supposed to be rotated to the rear in the event of a flat) no longer match the rear tires.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Shark_Bait88 (10-17-2018) |
#5 | |
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | Stang70Fastback (10-17-2018) |
#6 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | scottryan (10-18-2018), tyler_win_photo (10-17-2018) |
Definitely run a 35 series tire. 40 series with a 265 section is way too thick in terms of sidewall. And like others have noted, your TCS is not going to like it.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#8 | |
Financial Distress
| The Following User Says Thank You to scottryan For This Useful Post: | Tcoat (10-18-2018) |
Drives: 2014 GT86
Sidewall height is given in "%" from width, not absolute values. So of course, wider tires with same procentual profile height will have also higher sidewall. While it is not that precise, simplest rule of thumb is when you up one of tire sizing, to keep diameter somewhat same, you lower other tire sizing parameter.
If one wishes for some weird tire choices, eg. for staggered setup (also not advised on these cars, but some go for such for sake of arguable looks and to fit max possible width tires, which is also not advisable), just google for tire calculator and use any of found online calculators to see how similar or dissimilar different sized tires will be. |
| The Following User Says Thank You to churchx For This Useful Post: | Leonardo (10-18-2018) |
| Has anyone tried to replace the rear speakers with a sub and/or larger speakers? | soilent | Electronics | Audio | NAV | Infotainment | 9 | 12-28-2017 03:48 PM |
| Slightly stiffer rear sways make a difference??? | SwaggFPS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 10-24-2016 07:48 PM |
| HIC ROOF Spoiler$100/TRD REAR bumper rep$100/slightly bent Raven hood $100 | VakaGT | Exterior Parts (Aero, Lighting, Etc.) | 16 | 07-11-2016 01:49 AM |
| Larger Rear Wheels - Tacky or Acceptable? | Orly | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 02-28-2010 11:16 PM |
