Drives: Legacy
tS no winter package on Tire Rack?
I have a tS and was curious if the wheels/tires that work for PP would also work for the tS?
Also is there any wheels that TR sells that don't require alternate lug nuts? |
Drives: 2018 BRZ tS
Also curious about this!
Drives: 2014 GT86
try brz with PP package, if brembo fitment you are after.
Twins stock lugnuts are of very common for aftermarket wheels 60dg taper conical seat. In most cases stock lugnuts will do. |
Drives: Legacy
Is there a Tirerack rep who can give advice?
Senior Misanthrope
Drives: Legacy
I was going to park it for the winter and drive my beater car but then I’d be missing out on driving the BRZ so much.
A.K.A. Starlord
Drives: 2015 Series.Blue
The tS has the same brakes as the Performance Pack vehicles. Just select a PP variant, and you should be fine.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
Most wheels that fit the twins will probably clear with small 5mm spacer.
2013 Series 10 FRS #553
Drives: Legacy
I don't want to mess with spacers, do you think wheels certified for PP would work with tS?
#10 |
as others said yes as they use the same brakes
#11 | |
Thanks
It was a lot of fun working on my BRZ with mininal rust. Mine was exposed the first year but after that it was off the road for winter. It did start rusting the exhaust and some fasteners but not too much. Anyway that is my opinion. I tracked and had track parts on my car so may be different for you.
| Tire rack giving me a hard time on tire size, so please help! | NOI | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 09-03-2017 06:27 PM |
| DIY - Tire Rack | KDad2 | DIY (Do-It-Yourself) Guides | 13 | 11-11-2016 01:30 PM |
| Eibach Pro-kit from tire-rack | Z86 | AUSTRALIA | 0 | 07-13-2012 06:14 PM |
| Brz limited on the rack at tire rack | Nate219BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 07-06-2012 03:01 PM |
| Tire Rack still needs a BRZ! | Lonewolf | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-12-2012 02:35 PM |
