Old 10-12-2018, 02:13 PM   #1
dstrout
dstrout's Avatar
Mounting tow strap?
How did you / would you mount a soft tow strap? The problem is that if you find a bolt with the weird threads for where the stock tow eye screws in, the direction of pull is at right angles to the plate on the strap, which seems Bad.
I am thinking of welding a 3” x .125 plate to the bottom of the crash bar that sticks out far enough to let me bolt the strap to it. It seems like there must be a better idea out there.
All suggestions appreciated!
dstrout is offline   Reply With Quote
Mounting tires and different mounting equipment BR-ZED Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 07-08-2018 11:41 AM
Tamara tow strap Dreyup Cosmetic Modification (Interior/Exterior/Lighting) 13 07-09-2017 04:03 PM
Tow strap for bars FutureFT86 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-17-2017 07:01 PM
rear tow strap karma003 Cosmetic Modification (Interior/Exterior/Lighting) 0 07-23-2013 09:00 PM
Help me strap down my tires qoncept Tracking / Autocross / HPDE / Drifting 5 06-20-2013 04:06 PM
