Old 10-10-2018, 02:49 AM   #1
86MLR
86MLR's Avatar
When does power break the drivetrain
I'm contemplating getting some form of boost
When do people start breaking gearboxes, axles and other driveline parts.
I'm looking at not surpassing the limits of the drivetrain
I've killed boxes before by throwing too much torque at them
250nm, 300nm, 350nm
I've had a search but I cannot find much info, apart from one post where the member stated he was eating gearboxes at 375 nm
Car is a daily that gets thrashed, sees some khana and the occasional, Read: rare, track day
No slicks, only summer tyres like RE003, RS4, Starspecs
235 tyre size, I assume that plays a part.....
Cheers for any relevant information
Old 10-10-2018, 03:49 AM   #2
86MLR
86MLR's Avatar
I should have kept looking
250nm max capacity
At least now I know my max goal for torque
Old 10-10-2018, 04:04 AM   #3
86MLR
86MLR's Avatar
From some quick calcs the AZ6 is good till 228hp?
Damn
Unless my info, or calcs are wrong, there is a good chance they are, I hope they are......
I was hoping it would be good to at least 300-350hp atw, or at least 330nm.
Old 10-10-2018, 04:04 AM   #4
Verl0r4n
Drives: GT86
Are you sure? I thought the product code was 6MT which isnt listed there ?
Edit: wait nvm, are they really that old?
Sent from my SM-G950F using Tapatalk
Verl0r4n is offline   Reply With Quote
Old 10-10-2018, 04:12 AM   #5
Verl0r4n
Drives: GT86
Perhaps those figure are calculated using the stock clutch which is known to be weak.
Old 10-10-2018, 04:57 AM   #6
There is no rule of thumb.
It depends on your setup, your tune, and how you drive it.
The Following 7 Users Say Thank You to CSG Mike For This Useful Post:
bfrank1972 (10-10-2018), Kris86 (10-10-2018), Leonardo (10-10-2018), mrg666 (10-10-2018), PhyrraM (10-10-2018), Summerwolf (10-10-2018), Tcoat (10-10-2018)
Old 10-10-2018, 06:06 AM   #7
86MLR
86MLR's Avatar
Coming from Nissans with the Skyline box, anything over 500nm on semi slicks as your going to have issues, unless you drive like miss daisy.
Back in the day my OEM gearboxes were a consumable item.
Just spooling it up on full throttle would kill it pretty quick.
Edit: In the end the 33 was running 750nm, I was always on the hunt for new and used boxes, I couldn't justify the outlay for a built box when a new OEM cost 1.5k and I could pick up used for a couple of hundred.
I'm to old and jaded to be swapping out boxes every couple of months.
I just don't want to go down that path again, I want to find the limits of the OEM driveline and then make power accordingly.
Old 10-10-2018, 10:32 AM   #8
Grady
Grady's Avatar
how you drive it.
Most important.
The Following User Says Thank You to Grady For This Useful Post:
ermax (10-10-2018)
Old 10-10-2018, 11:49 AM   #9
bfrank1972
Drives: 2013 FR-S Argento
Yup. Examples:
If you constantly pound on it at the drag strip with drag radials, speed shifting all the way down, you'll be able to break things much faster with much less torque.
If you're lowered a lot, with a lot of rear camber, without supporting mods, you will increase stress on your axles/cv joints.
If you're running a positive displacement supercharger with tons of mid range torque, and 'stomp on it' a lot, you'll potentially increase shock stress on your engine internals + drivetrain.
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
Tcoat (10-10-2018)
Old 10-10-2018, 01:58 PM   #10
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
3 years of JRSC with 265whp, 10+ track days a year in advanced group... no problems
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
CSG Mike (10-10-2018)
Old 10-10-2018, 02:10 PM   #11
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
You'll start running into problems at 300whp. First you'll need a better clutch. Then you'll bend rods around 320. Then the trans will go around 400.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 10-10-2018, 02:17 PM   #12
Lets throw some monkey wrenches into all the misinformation and assumptions.
I've broken many transmissions at even 280whp. Why? Because transmission failures are not dictated by horsepower, but by torque and load.
I've broken axles both NA and FI. Axle failures are dictated by shock load, tire grip, and articulation of the CV joint. Big power can accelerate this in an unrelated manner, because guys with big power also tend to run stickier tires, which can exert a much higher shock load to the axles.
Clutches are also rated in torque. The stock clutch can hold 325-350whp, depending on the setup.
riboyster (10-10-2018), Tcoat (10-10-2018)
Old 10-10-2018, 02:18 PM   #13
Easy solution? Run the Harrop supercharger, off-the-shelf, with their provided tune.
No fueling modifications necessary. No need for an upgraded clutch. Trans will hold just fine. Axles will be okay unless you're drifting or drag racing (and would fail NA over time; unrelated to the SC).
86MLR (10-10-2018), Tcoat (10-10-2018)
Old 10-10-2018, 02:18 PM   #14
riboyster
riboyster's Avatar
Very true. Most people pushing 300hp have enough tq for it to happen though.
Mods to reduce drivetrain power loss? FRSW12 Engine, Exhaust, Transmission 31 12-28-2015 05:10 PM
Stock Engine / Drivetrain Power Limits lokiwho Engine, Exhaust, Transmission 13 12-18-2015 12:22 AM
Max power for factory drivetrain and engine internals solidONE Forced Induction 64 09-23-2013 01:16 PM
Drivetrain Slop TheseColorsDontRun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-12-2013 11:12 AM
