Old 10-08-2018, 12:25 PM   #1
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Mocal sandwich plate coming loose
Hey folks! So I installed a Perrin oil cooler kit earlier this year, and have had a somewhat recurring issue with the sandwich plate coming loose and leaking oil.
It looks like part of the issue could be that the adapter for one of the lines makes contact with the stock intake box, which I'm guessing applies pressure in a counter-clockwise direction under load and over bumps. Another factor is simply that the design of the Mocal sandwich plate makes it difficult to properly tighten with most sockets.
Has anyone else had this same issue? Were you able to orient the plate so that the lines have sufficient clearance from the stock air box? Mine actually has had the adapter melt the plastic a bit.
Also, any recommendations for a thin walled 27mm socket that will make tightening the sandwich plate easier?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-08-2018, 12:52 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I just use a large crescent wrench. Doesn't seat super well but still gets adequate torque.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
DarkPira7e (10-08-2018), Shark_Bait88 (10-08-2018)
Old 10-08-2018, 02:09 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
I had a similar issue with my Jackson Racing kit. I believe they fixed it now by removing some material around the bolt so you can fit a socket completely on it.
For me I used a 12 point socket and 1/2" ratchet. Apply downward pressure directly above the socket and turn it slowly so as to not slip off and round it. Haven't had any leaking after I did this.
Mine also contacts my air box but if you position it JUST RIGHT it won't touch even on track driving. The hard part is changing the air filter lol
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 10-08-2018, 02:17 PM   #4
DarkSunrise
DarkSunrise's Avatar
Ive got a Perrin oil cooler. I was able to position mine to give about a half inch of space between the lines and the air box.
I had a machine shop take some material off an existing socket to make it fit. Much easier to tighten down that way.
No problems with leaks or loosening, even after a dozen plus track days.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 10-08-2018, 04:08 PM   #5
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
I used a small pneumatic grinder and made room for my socket to fit properly. Then cleaned it off really really well....
Tonrogs is offline   Reply With Quote
Old 10-09-2018, 01:57 AM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I documented my similar experience here: http://www.ft86club.com/forums/showthread.php?t=127021
Originally Posted by humfrz
I'm old and lazy
Mocal Oil Cooler Thermostatic Sandwich Plate FS pgranberg11 Engine, Exhaust, Bolt-Ons 2 05-17-2018 12:10 PM
Mocal Thermostatic Oil Sandwhich Plate DustinS Engine, Exhaust, Bolt-Ons 0 04-17-2018 09:55 AM
Help with oil sandwich plate BIRDMAN408 Engine, Exhaust, Transmission 3 03-15-2018 01:00 AM
Mocal-sp1t-fa20 oil sandwich plate (SOLD) louistrann Engine, Exhaust, Bolt-Ons 0 05-15-2017 08:42 PM
Mocal sandwich plate SOLD Joesurf79 Engine, Exhaust, Bolt-Ons 5 10-15-2016 10:56 PM
