Old 09-28-2018, 12:39 PM   #1
BRZbliss
BRZbliss's Avatar
Drives: 2014 BRZ
Will a Tein coilover wrench work on KW v3s?
Will a Tein coilover wrench work on KW v3s? I tried searching but had no luck. The backstory is that I'm deciding to buy a used set of kw v3 coilovers as a backup, and I currently have the Tein Flex A coilovers which may go out at one point. Depending on the compatibility, I may just buy another wrench to make it work. Any feedback would be greatly appreciated!
BRZbliss is offline   Reply With Quote
Old 09-28-2018, 01:05 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
From my experience, I've used my Tein spanner wrenches on a couple different coilovers on different cars (Tanabe, HKS) and it works.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
BRZbliss (09-30-2018)
Old 09-28-2018, 01:11 PM   #3
n0thing
Drives: Subaru BRZ
You don't really need a wrench for KW. Once you loosen the grub screw, the plastic ring can be turned by hand even when it's on the vehicle, provided that the threads are clean. Moreover, the ring on KW doesn't need to be locked against anything.
To answer your question, probably not, because the KW wrench doesn't fit on the Tein.
n0thing is offline   Reply With Quote
The Following 2 Users Say Thank You to n0thing For This Useful Post:
BRZbliss (09-30-2018), Tristor (09-28-2018)
WTB: Tein Flex Z Coilover Tt3Sheppard Want-To-Buy Requests 7 03-27-2017 12:54 PM
Tein coilover install help klearfade Southwest 8 08-12-2015 04:15 PM
FS: Tein Flex Coilover Jade 86 Brakes, Suspension, Chassis 43 06-15-2013 09:35 PM
TEIN COILOVER SPRINGS jammz Brakes, Suspension, Chassis 0 04-01-2013 01:33 AM
