Old 09-24-2018, 04:36 PM   #1
ls1ac
ls1ac's Avatar
Valenti tail light intermittent
After several years my Velenti tail lights are having intermittent segment fail. I was following my son in my car and most of the time one segment (three LEDS) of the amber turn would not work, and the same for the red brake LEDS.
Has anyone else had this problem? If so do you have an answer?
I feel that it is a "cold" solder joint, and plan to take the light apart to resolder the joints. Has any one taken these lights apart? Like to paint.
I really like these lights but not enough to buy a second new set.
Old 09-25-2018, 08:55 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Search on here, I've seen a few threads about this issue and one guy even took his apart and re-soldered the circuit board.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-25-2018, 02:36 PM   #3
ls1ac
ls1ac's Avatar
That is what I plan to do, Looking for some info on separating the lens from the light. I am sure there is a better way than a chisel and hammer.
Old 09-25-2018, 02:38 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
There is a DIY about oven baking them... Let me see...
Here are a few.
http://www.ft86club.com/forums/showthread.php?t=38101
http://www.ft86club.com/forums/showthread.php?t=12312
video shows how to cut them apart with a hot knife.
I LIKE TIRES!
ls1ac (09-25-2018)
Old 09-25-2018, 02:43 PM   #5
8RZ
The Gunshine State
8RZ's Avatar
I'm not sure about those tails but I've had success with baking headlights in the oven to loosen the glue, low heat.
Current DD: M235i
Old 09-25-2018, 03:04 PM   #6
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
My Valenti's are failing as well in the same manner described, but I'm probably just going to sell mine cheap. I hear it's a fairly common issue with these lights after about the 1.5-2 year mark.
MCTeeJ is offline   Reply With Quote
Old 09-25-2018, 04:57 PM   #7
ls1ac
ls1ac's Avatar
I cut away the inside of the dust shield to get a look at the inside. I found that the daughter boards had to come out toward the lens. The lens is not glued in the normal manor, it is either sonic welded or RF welded together. Making separation almost impossible.
The parts are not board mounted witch means that there is movement and after vibration and time the solder joint can crystalize and become intermittent if not perfect.
I can get to only a few with the opening I made.
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
8RZ (09-26-2018), kevaughan (09-13-2021)
Valenti tail light signal light issue djdnz Cosmetic Modification (Interior/Exterior/Lighting) 70 12-03-2017 12:49 AM
Valenti Tail Light Problem H-TownBrz BRZ First-Gen (2012+) — General Topics 7 09-17-2016 06:05 AM
Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 nigel-jdmparts Exterior Parts - Lighting 14 06-23-2015 06:32 AM
Valenti Tail light on GBS alpine Cosmetic Modification (Interior/Exterior/Lighting) 0 01-24-2014 10:16 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
